a few things you dont wanna see......
PostPosted: Tue Jan 06, 2009 11:40 pm    Post subject: a few things you dont wanna see...... Reply with quote
when taking apart an engine
PostPosted: Wed Jan 07, 2009 7:45 am    Post subject: Reply with quote
Carniage rules!
PostPosted: Wed Jan 07, 2009 7:58 am    Post subject: Reply with quote
DOH! Shocked
PostPosted: Wed Jan 07, 2009 1:45 pm    Post subject: Reply with quote
Carniage rules!
Cheers to that!
PostPosted: Wed Jan 07, 2009 1:50 pm    Post subject: Reply with quote
Quasi-Traction wrote:
Carniage rules!
Cheers to that!
Hey, if this is just gonna be a carnage pic post, I'm game. Very Happy
BTW, what went through the cylinder Greg?
PostPosted: Wed Jan 07, 2009 2:45 pm    Post subject: Reply with quote
no idea the heads and valves look fine its weird
PostPosted: Wed Jan 07, 2009 7:00 pm    Post subject: Reply with quote
pull the Valves out of the head. I know mike intially thought his valves were fine after his motor let the rod/piston cut loose, and found they were bent later.
it might be a paranoid double-check, but its better to find out now before you replace stuff, and re-assemble and find out you have a leakdown or valvetrain problem.
PostPosted: Wed Jan 07, 2009 7:50 pm    Post subject: Reply with quote
that engines not going back in im relacing it with the engine out of the white bird , the white one had a few to many issues so i parted it out for my other two ws6's anyone wants the heads or the block let me know i wanna build a 350 later
