Posted: Sun Jan 04, 2009 8:15 pm Post subject: Check this out |
So I mentioned in another thread that my Camaro had some sort of bad inbalance thing going on in the engine. Well today I busted her out of a pile of snow and took a look at it. The harmonic balancer seperated the outer ring from the hub and was just riding on there loose. I snagged the balancer off the GTA sitting here and she's good as new again.
Then I went sideways to celebrate!
Posted: Sun Jan 04, 2009 9:12 pm Post subject: |
Did you install it with a hammer?? At least it was a fairly simple fix. |
fiveoformula Member
Posted: Sun Jan 04, 2009 9:25 pm Post subject: |
Do those generally wear out easily? _________________
'88 FORMULA |
alloy T56 Elitist
Posted: Sun Jan 04, 2009 11:19 pm Post subject: |
| fiveoformula wrote: | | Do those generally wear out easily? |
Not unless you install them with a "Hammer"  |
Posted: Sun Jan 04, 2009 11:27 pm Post subject: |
| alloy wrote: | | fiveoformula wrote: | | Do those generally wear out easily? |
Actually, old ones do it sometimes. Rubber between the two pieces dries up and cracks. Not something to get too worried about though. |
Posted: Sun Jan 04, 2009 11:32 pm Post subject: |
| pfff, a little JB Weld and it is good as new. |
Posted: Mon Jan 05, 2009 7:23 am Post subject: |
You know the old 327 cranks didn't have a threaded hole. The specified means was installing with a hammer. _________________ A redline a day keeps the carbon away! |
Posted: Mon Jan 05, 2009 8:31 am Post subject: |
| I installed the new one with a hammer, at least until I could enough threads on the bolt engaged to run it on. Just hit the hub, not the outside ring. |
Posted: Mon Jan 05, 2009 11:15 am Post subject: |
Whoa. Yikes. Could it have walked off if left like that? _________________
Posted: Mon Jan 05, 2009 5:08 pm Post subject: |
Good thing you caught that when you did. That could have been very nasty, and a much more expensive fix. _________________
