1LEWannabe New Member
Posted: Sun Sep 05, 2004 8:13 pm Post subject: seems i have a problem here... |
on my 86 Z28, i had a problem develop when you gave it gas, under fairly heavy acceleration, it would die. so after replacing the fuel pump and filter, problem still remained. so through some troubleshooting, myself and a friend discovered that the carb was filling the secondaries at IDLE. so i bought an Edelbrock Streetmaster (OLD SCHOOL) intake and a Holley 650 dual feed, single-pump carb. put those on along with a vac advance distributor to get rid of the computer. the problem has gotten better but it is still here. so Mark and myself have been tuning the Holley for about 2 days. it feels AWESOME through 1st gear (leaves more rubber off the line then my LB9 use to) but about midway through 2nd, it is dead. usually if you take your foot off the gas when it starts bogging, it will stay running. but if you hold the gas down, it COMPLETELY dies. and after it bogs, you usually can't give it gas for about 10-15 secs, like it is having to recover. we also have replaced the cap, coil, plugs and wires. but still, the problem exists...any thoughts...?
Josh _________________ 1986 Chevy Camaro Z28
305 LG4 (blech) and 700R4...
Edelbrock Streetmaster intake and Holley 650 dual feed 4 bbl carburetor are the only mods for now...will do more when i return from Iraq... |
Camaro350Z28 Member
Posted: Sun Sep 05, 2004 9:05 pm Post subject: |
i have no clue what was causing that problem on my 85.. i kinda hurt someones quarter panel from that problem too... i have no idea what it was, i thought it was too much gas.. either carb runnin bad or maybe too much fuel pressure.. not sure though. think carb should have like 5-7 psi or somehtin like that _________________ 1985 Z28. Don't know what im doing stupid 4th gen broke me.
Best 1/4 - 13.8 @ 101.98 60' 2.27 |
84transam383 Banned
Posted: Sun Sep 05, 2004 11:22 pm Post subject: |
well...some more news..its been rejetted,floats readjusted,advanced it a little bit..
did a test..from a full throttle standing start,at about 3 grand in second gear,it started to die so josh kept it floorboarded to kill it...
fuel filter,and front fuel bowl were bonedry...
thinking the fuel line or sockfilter in the tank is clogged with some kinda shizzle...
DAMN chevys... |
84transam383 Banned
DAMN chevys...
nothin runs like a dodge |
Posted: Mon Sep 06, 2004 3:02 am Post subject: |
well, the car is FIXED!! turns out the fuel sock was clogged with crap and now after blowing some air through the lines it is good. sometime within the next week i will drop the rear axle and tank and clean it right...
Josh
p.s.- Marko...DODGE-Drips Oil Drips Gas EVERYWHERE!! _________________ 1986 Chevy Camaro Z28
84transam383 Banned
Posted: Mon Sep 06, 2004 5:32 am Post subject: |
1LEWannabe wrote: | well, the car is FIXED!! turns out the fuel sock was clogged with crap and now after blowing some air through the lines it is good. sometime within the next week i will drop the rear axle and tank and clean it right...
Josh
p.s.- Marko...DODGE-Drips Oil Drips Gas EVERYWHERE!! | p.s. josh,it STILL runs better then the camaro
and whos vehicle leaves puddles?
ram dont |
Posted: Mon Sep 06, 2004 1:54 pm Post subject: |
oh Marko, did ya mention to everyone here how the LG4 PULLED on the Ram on the freeway? just figured i would mention that, and the fact that that was BEFORE the new carb and intake...
just bustin your ballz, its really hard and pointless to compare a Ram and a Z28
84transam383 Banned
Posted: Mon Sep 06, 2004 2:27 pm Post subject: |
1LEWannabe wrote: | oh Marko, did ya mention to everyone here how the LG4 PULLED on the Ram on the freeway? just figured i would mention that, and the fact that that was BEFORE the new carb and intake...
Josh | well,a little clarification...my ram was stone stock when that happened...
its awesome your camaro thats weighs about 2k pounds less then my ram,can BARELY pull on it..
race me now biatch |
Posted: Mon Sep 06, 2004 7:45 pm Post subject: |
well, as Marko now knows, guess i wont be racing ANYONE seeing as as soon as we fixed the fuel problem, something happened and she dropped cylinder #1. so now it smokes, it misses, and generally runs like crap...guess ill be in the market for a motor now, lol...
alloy T56 Elitist
Posted: Wed Sep 08, 2004 7:13 am Post subject: |
1LEWannabe wrote: | she dropped cylinder #1.
Josh |
Did you pull a compression check on all cylinders? Don't condem the entire motor til you do this. |
