91 base model bird to 86 Trans Am Grid Tail light swap
Red Bird
1991 Pontiac Firebird
PostPosted: Fri May 16, 2008 8:29 pm    Post subject: 91 base model bird to 86 Trans Am Grid Tail light swap Reply with quote
So i found a wrecked 86 trans am and i scored the rear hatch with wrap around spoiler, 16" gold pizza cutter wheels, and grid tailights. When i went to swap the tail lights in, the stock ones on my 1991 base model bird have the 4 tail light bulbs like the 86 does, but it also has two extra bulbs for the reverse and turn signal, that the 86 does not have. I got the harness that holds all the bulbs for the 86 trans am, but the connector is way different than the harness for the 91 bird. Any one run into this? any suggestions would be most apreciated.
1991 Firebird L03 T-5
PostPosted: Fri May 16, 2008 11:02 pm    Post subject: Reply with quote
i ran into this problem to, i ended up not using one brake light on each side and i spliced the wiring from the donor taillights onto mine as needed
'88 FORMULA
