90rsgnuguy42 New Member
Posted: Mon Aug 23, 2004 10:12 am Post subject: Worn out hood struts |
I need a worn out set of hood struts for my fiberglass hood. _________________ 90 RS, Eibach Springs, Spohn LCA's, LT1 cam, open element air filter, Dynomax Headers (thanks paul), 3.73 limited slip w/rear discs, B&M megashifter...so far |
Posted: Mon Aug 23, 2004 10:18 am Post subject: |
I pretty sure have a set you can have for 1 beer (I double check that I kept them, when i get home.)
If you need them in a big hurry, let me know, if not I can bring them up for the Labor Day gtg, if it happens. _________________
Posted: Tue Aug 24, 2004 5:17 am Post subject: |
Sold! At your convenience. It looks like the Labor Day gathering is at Northgate? _________________ 90 RS, Eibach Springs, Spohn LCA's, LT1 cam, open element air filter, Dynomax Headers (thanks paul), 3.73 limited slip w/rear discs, B&M megashifter...so far |
Posted: Tue Aug 24, 2004 5:27 am Post subject: |
| I don't know where it is, I am not sure if it is finalised yet. |
Posted: Wed Aug 25, 2004 5:19 am Post subject: |
| BTW, I did check last night. I do have both shocks. hopefully there is enough left in them to open a fiberglass hood. it wouldn't hold the steel hood up. |
