Posted: Thu Apr 03, 2008 3:48 pm Post subject: Dyno Day @ Turbo Tech. |
http://www.ls1tech.com/forums/showthread.php?t=871956
Just figured I'd post that up there for anyone in the area. I'm going to be there, maybe with my bird, maybe not. If I don't have my bird I'll have my coworkers 80 rabbit with a mild 1.8 FI engine. We just put Kook's LTs and Corsa catback on my buddies GTO so we're looking to see what it'll put down. From the looks of the other cars there, a lot less than them! _________________
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Fri Apr 04, 2008 12:17 am Post subject: |
Dude I can't belive I'm going to be stuck at work like three blocks from there.
Ian, do you know what time is this all going to go down? I think I'm probably going to draw a split that Saturday, so I can swing by from 3-6ish between my two shifts.
If it's later on in the afternoon the guys from the bootleg show might be able to come too, as that show is being advertised from 8am till 2pm. |
Posted: Fri Apr 04, 2008 5:55 am Post subject: |
I was planning on hitting the dyno in the morning and trying to hit the bootleg show later on. There are well over 30 cars dyno'ing, some trying for 800hp. |
85 T/A WS6 Member
Posted: Fri Apr 04, 2008 5:11 pm Post subject: |
Cool I save a T/Ale or a GXPale Ale for ya _________________
