kurfbird Member
Posted: Sun Aug 19, 2007 5:15 pm Post subject: Broken head bolt stuck in block HELP |
Help I broke a head bolt while removing my heads after the head gasket went bad. Car did not overeheat. I just put the socket on the bolt and it spung freely. I tried to drill and use and easy out but that did not work. Broke three wrenches.
Thinking of drilling out the bolt and using a tap on the threads. Is there another way that i Have not through of.
ENgine is still in car. its a 3.1 V6. _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Sellmanb Member
Posted: Sun Aug 19, 2007 8:03 pm Post subject: |
| Well, best thing you can do really is to send it to a machine shop and let them hassle with it. They have all the proper tools to take the bolt out without mucking up the block or getting metal shavings in the cylinders, etc... |
Posted: Mon Aug 20, 2007 12:13 am Post subject: |
| Depending on how messy you were with the drill.... get a square easy out in there. Lots of penetrating oil and let it soak. Might try a little bit of torch. Don't get too carried away as to not warp things. |
kurfbird Member
Posted: Mon Aug 20, 2007 12:34 am Post subject: Tried that |
I tried that but to no avail. Guess Iam going to be pulling the engine tomorrow. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Mon Aug 20, 2007 12:49 am Post subject: Re: Tried that |
| kurfbird wrote: | | I tried that but to no avail. Guess Iam going to be pulling the engine tomorrow. |
If the easy out isn't broken yet, more lube and more heat |
kurfbird Member
Posted: Mon Aug 20, 2007 5:03 am Post subject: going to give it another try this efternoon |
going to give it another try this afternoon _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
alloy T56 Elitist
Posted: Mon Aug 20, 2007 6:01 am Post subject: |
Use a product called PB Blaster. Get it at most parts stores. Soak it for a day or so, do this several times, let it it penetrate, then give it a try. It's great stuff. Much better than WD40 for something like this.
Can you take a pic of it and show us what you have to left work with? |
kurfbird Member
Posted: Mon Aug 20, 2007 9:26 am Post subject: Yes |
I have soemthing similar called yield. Yes I have been soaking it. I will try to figure out how to post pictures. The bolt is flush with the top of the block or a little below that. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Mon Aug 20, 2007 4:35 pm Post subject: |
| Yield should be decent. If the torch and easy out don't work, do you have a freind with a welder? I've welded nuts to the broken bolt before then used a wrench to turn the peice out. |
kurfbird Member
Posted: Mon Aug 20, 2007 4:50 pm Post subject: There is nothing to weld |
There is nothing to weld to the bolt is below the head surface. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kurfbird Member
Posted: Mon Aug 20, 2007 8:51 pm Post subject: |
| Plenty to weld to. You just have to be careful you don't weld it to the block. Done it many times. Build it up a little to center the nut.. then weld the center in. Even when you do hit the block surface, beings it's cast it won't stick very well anyway. Still I'd try the easy out and plenty of heat first. |
kurfbird Member
Posted: Mon Aug 20, 2007 9:12 pm Post subject: easy out is broken |
Easy out is now broken. Felt bolt starting to turn the easy out broke. Engine is going to be pulled. I am going to go back to my old motor and put rings in #1 cyl and put it back together. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Tue Aug 21, 2007 12:57 am Post subject: |
Hmm, that means you'd have a spare 350 lying around then. I'm kind of looking for a 350 for my car actually? give me a pm if you want me to take it off your hands. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
kurfbird Member
Posted: Tue Aug 21, 2007 5:56 am Post subject: no sorry its a 3.1 v6 |
no sorry its a 3.1 v6 _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
redlava Member
Posted: Tue Aug 21, 2007 6:40 am Post subject: |
| could you have drilled and tapped a reverse threaded smaller bolt into the larger broken bolt? |
redlava Member
Posted: Tue Aug 21, 2007 6:41 am Post subject: |
kurfbird Member
Posted: Tue Aug 21, 2007 9:09 am Post subject: Probably not |
Probably not its a head bolt and has to be torqued to 70 ft lbs. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Tue Aug 21, 2007 10:44 am Post subject: |
| i think he means that you could use the reverse threaded bolt to get the regular threaded bolt out. as you tightened it, your tightening forces would be exerted as loosening forces against the larger bolt. eventualy one would break. the new bolt, the threads you tapped, or the old bolt would be loosened. i once got a thermostat bolt i broke off in the cyl head of a jeep out this way. |
BigDaddyVu 12sec Club
Posted: Tue Aug 21, 2007 11:44 am Post subject: |
how far the threads stick out from the mating surface?? or how deep? _________________
