holley commander
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Fri May 25, 2007 10:59 am    Post subject: holley commander Reply with quote
so whats the differance between these????
http://store.summitracing.com/egnsearch.asp?Ntt=commander+950+tpi&searchinresults=false&Ntk=KeywordSearch&DDS=1&N=700+400235+215+115
PostPosted: Fri May 25, 2007 11:06 am    Post subject: Reply with quote
One for TPI and the other for a universal efi TBI
PostPosted: Fri May 25, 2007 11:08 am    Post subject: Reply with quote
I believe the 109 is the universal kit - the 'TPI' in the description might be a bit misleading. IIRC, Paul got the 109 kit and had to do some trimming/lengthening on parts of the harness - no big deal but more work than the 101 kit.
I used the 101.
Not sure why the 109 would be more expensive. I'm sure Paully will chime in.
scott in wa.
PostPosted: Fri May 25, 2007 11:13 am    Post subject: 950 Reply with quote
Iam seeing TPI, Universal, Each on both????
so not tbi but, both for TPI...hummmm.
100 bucks different////?
scott in wa.
PostPosted: Fri May 25, 2007 7:22 pm    Post subject: 0RDERED Reply with quote
Ordered the 101 kit from Scoggin Dickey......
$986.74
We are commited now!!!!!!!
I wonder how long it will take to get here??????????????
Just a little bit cheaper than summit...
scott
PostPosted: Fri May 25, 2007 8:17 pm    Post subject: Reply with quote
Summit has it labeled wrong:
Holley Website:
950-101 = Commander 950 Engine Management System Kit 1985–1992 GM TPI Engine applications.
950-109 = Commander 950 Engine Management System Kit Universal V8 Multi–Point Fuel Injection
