86 Iroc-Z possible ECM or Prom problem
J-Dog-III
PostPosted: Mon May 21, 2007 8:24 pm    Post subject: 86 Iroc-Z possible ECM or Prom problem Reply with quote
Me and my dad have been tinkering with his car, doing a tune-up and everything and have it running great so far. But when you first start the car it runs fine, go down the road 30-45 mph fine, but as soon as you wood it the engine knock sensor goes off. So my dad Took out the ecm and it's pin # 1227165AMU, and it has a ACDelco AUM323 prom in it. So when we tried to run the self-diagnostic, grounding A and B of the ALDL it wont do anything. So my question is, Is the prom that's in it wrong? and is it sending the wrong code to the sensor making it go off?
PostPosted: Mon May 21, 2007 9:28 pm    Post subject: Reply with quote
Further explain your problem.
Do you guys have a scan tool reading the knock sensor?
J-Dog-III
PostPosted: Mon May 21, 2007 9:54 pm    Post subject: Reply with quote
No, Under Load you can hear the knock sensor going off and then the check engine light comes on. But after that the car runs fine with no problems but the check engine light stays on after the sensor has been tripped and no further sensor going off
Sellmanb
PostPosted: Tue May 22, 2007 5:41 am    Post subject: Reply with quote
So you guys can actually hear it knocking on accell then? Or You can just feel the timing retard?
PostPosted: Tue May 22, 2007 8:11 am    Post subject: Reply with quote
If you can hear the knock something is way out and I doubt it's the ECM itself. The knock sensor senses pinging, and tells the ECM. The ecm then retards the timing until the ping goes away.
What code does the ECM spit out?
Could be your timing is off.
Engine deposits.
Bad Gas.
J-Dog-III
PostPosted: Tue May 22, 2007 8:21 pm    Post subject: Reply with quote
We already fixed the timing and that isnt it, and ran a new tank of gas through it. But it's weird becuase after the knock sensor goes off it runs fine, timing is normal and it dosent go off until the car is restarted
Sellmanb
PostPosted: Tue May 22, 2007 9:13 pm    Post subject: Reply with quote
Pardon me, I think I'm a bit confused. You say the knock sensor is going off, but you dont have a scanner or anything, so how can you tell? Does the SES light just pop up or something, and it's stored a knock sensor code?
Or can you hear knocking? Or what? Sorry if these are stupid questions, just want to get the facts straight.
J-Dog-III
PostPosted: Tue May 22, 2007 9:21 pm    Post subject: Reply with quote
You can hear the Knock sensor go off for like 2-3 seconds and then it goes off and the ses light comes on
PostPosted: Tue May 22, 2007 9:32 pm    Post subject: Reply with quote
K.. I think whats confusing is that you can NOT hear a knock sensor go off. You can't tell if one's going off at all unless you have a scan tool hooked up or maybe if it turns the check engine light on. Now if you are just hearing some knocks.. then thats a different. It's possible maybe that the engine starts knocking heavily before the knock sensor picks it up. It's possible the ESC module isn't working correctly.. lots of other things. But to really see whats going on you'd need a scanner.
PostPosted: Tue May 22, 2007 11:55 pm    Post subject: Reply with quote
describe this "knock sensor going off" noise. what does it sound like? what do you think is creating this noise? (IE a speaker emitting a beep, or is it coming from the engine itself, like a mechanical noise?)
PostPosted: Wed May 23, 2007 9:40 am    Post subject: Reply with quote
He's describing pinging or "engine knock."
Sellmanb
PostPosted: Wed May 23, 2007 11:55 am    Post subject: Reply with quote
OK, what octane gas are you putting in the car? I would put some octane booster (found at most gas stations and schucks, baxters, napa, etc) in the gas tank. If that helps, then you are just running too low a grade of gas.
PostPosted: Wed May 23, 2007 12:21 pm    Post subject: Reply with quote
If it's a stock car it shouldn't need higher than '87, however quality is an issue.
Arco gas ran like crap in all my 305s.
If it's knocking you need to check timing first and formost... then move to things like gas choice and spark plugs.
PostPosted: Wed May 23, 2007 5:15 pm    Post subject: Reply with quote
When I had the 305 in my car it wouldnt run on anything less then premium.. Traveling you could possibly get away with plus.. if you kept a light foot. That 305 knocked all the time.. and this is without an OD transmission. Now the 327 with lots more power runs fine on 87. Same ignition, same chip, no egr even.
EGR is another thing that helps prevent knock. If the valve isnt opening you can get knock too. From what I can tell from your description though I'm leaning towards an ESC module. I've had tbi trucks that would advance the timing, then you hear alot of audible knocking for a few seconds, finally the ecm would catch that and back the timing off and put the car in failsafe mode.
J-Dog-III
PostPosted: Wed May 23, 2007 7:01 pm    Post subject: Reply with quote
We already corrected the timing the first couple of days we had it, changed out spark plugs and it's still doing it. My dad was thinking it was the lower octane gas too. Probably gonna try that and see how it runs. Thx for the help
