   1989  Chevrolet  Camaro RS
				 Posted: Sun Apr 15, 2007 3:12 pm    Post subject: New injectors for the '89 |
				Turbo_Jimi and I decided to change out the 19lb injectors on my '89 RS 2.8 with the 24lb injectors from the 3.8 that used to be in his '98. We cleaned up the 3.8 injectors and installed them on the fuel rail with relatively no problems. The 24lb units are a little shorter than the stockers but fit with no problem and the car started right up. We had a fire extinguisher at the ready just in case. I did notice a smoother idle and slightly better low speed power. That may have had to do with the fact that my old injectors were extremely dirty. All in all it was an easy swap that seems to have resulted in better performance. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
   1989  Pontiac  GTA
				 Posted: Sun Apr 15, 2007 7:20 pm    Post subject:  |
				Good deal. A swap with no major incident or collateral damage is always a good thing. Bonus that the car runs too!
				 Posted: Sun Apr 15, 2007 9:29 pm    Post subject:  |
				Yeah, we were both surprised when it started on the first try (our projects rarely go this smoothly!)    |
   1988  Pontiac  GTA
				 Posted: Sun Apr 15, 2007 11:55 pm    Post subject:  |
				| have you done any tuning from stock? |
				 Posted: Mon Apr 16, 2007 7:36 am    Post subject:  |
				I bet your milage is going to go down hill unless you find a way to turn your fuel pressure down a bit.
At the same pressure you're adding probably around 20% more fuel. |
				 Posted: Mon Apr 16, 2007 4:21 pm    Post subject:  |
				| Yeah, I was thinking that an adjustable FPR would be a good investment now. I can already tell that shes using more gas but the engine is running great with a definite improvement in low speed power. My main reason for switching to a higher flowing injector is for my planned turbo project hopefully starting this summer. A Walbro fuel pump is also on the list of fuel system upgrades. |
