19lb Injectors
Project_1986_TA
PostPosted: Tue May 04, 2004 11:30 pm    Post subject: 19lb Injectors Reply with quote
I have a used set of 19lb an hour injectors. They still work but should probably be cleaned. Not sure what brand they are, i'll look tomorrow. Make an offer.
View user's profile Send private message Yahoo Messenger MSN Messenger
Gibby85
PostPosted: Fri May 07, 2004 11:59 am    Post subject: Reply with quote
Isn't that the stock rating for TPI injectors?
www.cardomain.com/id/gibbys85
PostPosted: Fri May 07, 2004 12:02 pm    Post subject: Reply with quote
Yes Sir.
PostPosted: Fri May 07, 2004 12:08 pm    Post subject: Reply with quote
Yes Sir.
Stock rating for 305 TPI injectors
350 TPI injectors are 22lbs
