MIDNITERIDER New Member
Posted: Fri Mar 16, 2007 3:49 am Post subject: 9th injector block off kit question??? |
Will be installing the kit tomorrow ..straight forward but what do you do with the 9th injector wiring???...just let it hang???
thanks _________________ 1988 Formula 350
13.93 @ 99.32mph |
pathology knight Member
Posted: Fri Mar 16, 2007 6:54 am Post subject: |
you should be able to take it all out and plug off the holes.
you'll need to plug or cover the injector hole, plus plug the hole in the back of the fuel rail where it "starts".
that should be it! _________________ we all gotta start somewhere.... |
Posted: Fri Mar 16, 2007 8:02 am Post subject: |
The 9th injector just runs off switches in the block, not the ecm. So you can follow the wires back to where ever and clip them or unplug them. |
Posted: Fri Mar 16, 2007 8:19 am Post subject: |
Thanks.....I do have that pricey block off kit already but it was just the wires for looks...what to do with them so to speak..
Thanks for the info... _________________ 1988 Formula 350
13.93 @ 99.32mph |
alloy T56 Elitist
Posted: Fri Mar 16, 2007 8:32 am Post subject: |
This is probably a dumb question, but why delete the cold start injector??? Unless you went to SD. |
Posted: Fri Mar 16, 2007 8:53 am Post subject: |
alloy wrote: | This is probably a dumb question, but why delete the cold start injector??? Unless you went to SD. |
My car is driven only on dry summer days and I find that it can backfire at times if I dont let the pump prime...never had a real need for the cold start....pulled the 3 amp crank fuse just to check this out. To me the 9th one is overkill for my driving needs as it has never seen the winter(original owner). _________________ 1988 Formula 350
13.93 @ 99.32mph |
Posted: Fri Mar 16, 2007 10:53 am Post subject: |
my 2.8 one was left unplugged by accident a few months back. noticed it when i pulled my dizzy 3 weeks ago. the car has never failed to start. in facti noticed NO difference without the colt start injector. thing had probably failed ages ago |
Posted: Fri Mar 16, 2007 10:55 am Post subject: |
I couldn't start my '85 305 TPI at all when the 3amp fuse was out. |
Posted: Fri Mar 16, 2007 11:15 am Post subject: |
Twilightoptics wrote: | I couldn't start my '85 305 TPI at all when the 3amp fuse was out. |
Mine would start every time I pulled the crank fuse.....read it years back that this disengages the 9th.....cant remember the details("sometimers" setting in ) probably on TGO... _________________ 1988 Formula 350
13.93 @ 99.32mph |
Posted: Fri Mar 16, 2007 10:00 pm Post subject: |
The cold start injector is run from its own thermostat called the cold start switch.
Chiltons says this about the switch (and I quote)
Opens above 35*C or 95*F. Stays closed for 8 seconds when coolant is -20*C or -5*F
So once the thermostat closes (turns on the injector at -5*F) it will stay on for 8 seconds or if the thermostat hits 95*F. SO if you don't drive your car at almost 30* below freezing, you'll be fine to disconnect it. _________________ E30
Posted: Sat Mar 17, 2007 1:16 pm Post subject: |
Its in and starts the first crank....Thanks to all the above members that helped out
Much appreciated!!!!
Bill _________________ 1988 Formula 350
13.93 @ 99.32mph |
