9th injector block off kit question???
MIDNITERIDER
New Member
PostPosted: Fri Mar 16, 2007 3:49 am    Post subject: 9th injector block off kit question??? Reply with quote
Will be installing the kit tomorrow ..straight forward but what do you do with the 9th injector wiring???...just let it hang???
thanks
1988 Formula 350
13.93 @ 99.32mph
pathology knight
PostPosted: Fri Mar 16, 2007 6:54 am    Post subject: Reply with quote
you should be able to take it all out and plug off the holes.
you'll need to plug or cover the injector hole, plus plug the hole in the back of the fuel rail where it "starts".
that should be it! Wink
we all gotta start somewhere....
PostPosted: Fri Mar 16, 2007 8:02 am    Post subject: Reply with quote
The 9th injector just runs off switches in the block, not the ecm. So you can follow the wires back to where ever and clip them or unplug them.
MIDNITERIDER
New Member
PostPosted: Fri Mar 16, 2007 8:19 am    Post subject: Reply with quote
Thanks.....I do have that pricey block off kit already but it was just the wires for looks...what to do with them so to speak..
Thanks for the info...
1988 Formula 350
13.93 @ 99.32mph
PostPosted: Fri Mar 16, 2007 8:32 am    Post subject: Reply with quote
This is probably a dumb question, but why delete the cold start injector??? Unless you went to SD.
MIDNITERIDER
New Member
PostPosted: Fri Mar 16, 2007 8:53 am    Post subject: Reply with quote
My car is driven only on dry summer days and I find that it can backfire at times if I dont let the pump prime...never had a real need for the cold start....pulled the 3 amp crank fuse just to check this out. To me the 9th one is overkill for my driving needs as it has never seen the winter(original owner).
1988 Formula 350
13.93 @ 99.32mph
PostPosted: Fri Mar 16, 2007 10:53 am    Post subject: Reply with quote
my 2.8 one was left unplugged by accident a few months back. noticed it when i pulled my dizzy 3 weeks ago. the car has never failed to start. in facti noticed NO difference without the colt start injector. thing had probably failed ages ago Rolling Eyes
PostPosted: Fri Mar 16, 2007 10:55 am    Post subject: Reply with quote
I couldn't start my '85 305 TPI at all when the 3amp fuse was out.
MIDNITERIDER
New Member
PostPosted: Fri Mar 16, 2007 11:15 am    Post subject: Reply with quote
Mine would start every time I pulled the crank fuse.....read it years back that this disengages the 9th.....cant remember the details("sometimers" setting in Wink ) probably on TGO...
1988 Formula 350
13.93 @ 99.32mph
PostPosted: Fri Mar 16, 2007 10:00 pm    Post subject: Reply with quote
The cold start injector is run from its own thermostat called the cold start switch.
Chiltons says this about the switch (and I quote)
Opens above 35*C or 95*F. Stays closed for 8 seconds when coolant is -20*C or -5*F
So once the thermostat closes (turns on the injector at -5*F) it will stay on for 8 seconds or if the thermostat hits 95*F. SO if you don't drive your car at almost 30* below freezing, you'll be fine to disconnect it.
MIDNITERIDER
New Member
PostPosted: Sat Mar 17, 2007 1:16 pm    Post subject: Reply with quote
Its in and starts the first crank....Thanks to all the above members that helped out
Much appreciated!!!!
Bill
1988 Formula 350
13.93 @ 99.32mph
