Dyno Poll ! ! !
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Post new topic   Reply to topic    Cascade Crew Forum Index -> Event Calendar
Jan 27th, will it work?
Yes, I will be there, and will Dyno this day
69%
 69%  [ 9 ]
I will not be dynoing, but will attend
23%
 23%  [ 3 ]
I can not make it, the other dates work better.
7%
 7%  [ 1 ]
Total Votes : 13
PostPosted: Tue Dec 19, 2006 12:27 pm    Post subject: Reply with quote
Al, your car is a LO3, it was only rated at 170hp from the factory. I am pretty sure it won't do 200hp.
littletank170
PostPosted: Tue Dec 19, 2006 12:28 pm    Post subject: Reply with quote
id be happy to get 170.
LB985IROC
1995 Chevrolet Camaro Z/28
anyways, if someone wants to ride wiht me your more then welcome if you dont mind rock music, loud exhaust, excesive speeding, or pitching in for gas
Cadillac of Bellevue
Retail parts sales
vee-six
littletank170
PostPosted: Tue Dec 19, 2006 12:29 pm    Post subject: Reply with quote
if im not workingby then i will. i dont mind any of those.
PostPosted: Tue Dec 19, 2006 12:50 pm    Post subject: Reply with quote
Thanks John, I already knew that and don't really expect to get 170, but I'd be happy with it. IIRC, the 3.1 V6 is rated for 140 from the factory, I'd be happy to get that too.
LB985IROC
PostPosted: Tue Dec 19, 2006 2:00 pm    Post subject: Reply with quote
well im hoping for 300 rwhp so you know we all can be disapointed together think of it this way....they arent fords
Retail parts sales
vee-six
PostPosted: Tue Dec 19, 2006 5:28 pm    Post subject: Reply with quote
my 86 2.8 is rated at 135HP. i am expecting 100 @ the wheels. 1988 GTA is rated @ 230. i will by psyched to get 220@ the wheels.
LB985IROC
PostPosted: Tue Dec 19, 2006 5:34 pm    Post subject: Reply with quote
im definately excited about all the driving ill be doing woohoo
Retail parts sales
vee-six
PostPosted: Tue Dec 19, 2006 5:36 pm    Post subject: Reply with quote
Sounds pretty reasonable Tony.
LB985IROC, is your entire combo in your sig or is there more? Also, curious to know what the combos were on these:
1993 trans am 14.376@110mph
1985 IROC-Z 14.765@108mph
Thanks!
littletank170
PostPosted: Tue Dec 19, 2006 5:39 pm    Post subject: Reply with quote
i am really interested in the IROC. i'd like to get mine there by the time the track opens.
thanks
PostPosted: Tue Dec 19, 2006 9:22 pm    Post subject: Reply with quote
I am going to try and make it this year, hoping for 322 at the wheels this time. Cool
LB985IROC
PostPosted: Wed Dec 20, 2006 7:33 am    Post subject: Reply with quote
well those are the only f-bodys ive owned the IROC had a 350 TPI 4 bolt (unknown internals), tpi performer cam, accel injectors, granatelli AMAFS, K&N filters, edelbrock headers, cat delete, air delete, flowmaster 3.25 exhaust B&M street/strip shift kit, 3.73 gears, accel coil, accel wires, and a bored TB....thats al i can remember it had at this moment...
the 93 trans am had magnaflow exhaust catco cat, SLP headers, slp CAI
by the way the trans am time should have been faster but i hesitated and got almost a full second reaction time Rolling Eyes
....oh and i never could get the iroc to run right....
Retail parts sales
vee-six
PostPosted: Wed Dec 20, 2006 12:42 pm    Post subject: Reply with quote
Laughing I'll say, those are terrible numbers for that combo, man. IIRC the L98 was a 2-bolt main too.
BTW, my work situation is still up in the air right now, so I don't know if I'll be able to make it down. Sad
PostPosted: Wed Dec 20, 2006 12:59 pm    Post subject: Reply with quote
Thanks LB9, I was curious because your MPH is considerably higher than the E.T. would indicate. Almost seems unpossible with those mods. Reaction time is not calculated into E.T.
Both of those MPH indicate over 400 horsepower assuming a normal heavy F-body.
What track did you run at?
PostPosted: Wed Dec 20, 2006 1:29 pm    Post subject: Reply with quote
G-tech going down hill with a 40mph tail wind?
Laughing so hard it hurts
LB985IROC
PostPosted: Wed Dec 20, 2006 1:41 pm    Post subject: Reply with quote
yea i took those down i thought thats what theyw ere but i cant find the time slips i think iw as off on the mph i pretty much guessed so yea but the times are correct also it was not a L98 it was a 4 bolt 350 from a 69 z28 with 2.02 camel hump heads and yea it ran like crap (hense why i sold it f***ing tpi) and the borg-warner posi never locked up when i launched it
Retail parts sales
vee-six
PostPosted: Wed Dec 20, 2006 2:09 pm    Post subject: Reply with quote
If I can get mine to stay running.... I hope to have brakes done and intake tract done. Going for 321 HP at the wheels Smashy Smashy Very Happy
PostPosted: Wed Dec 20, 2006 2:34 pm    Post subject: Reply with quote
not to be a Dick, but I'm glad someone called him on it. I've had a problem with those times since I first read his sig....
my fastest time EVAH on any car I've ever owned was my V6 4th gen running a 15.68 @ 89mph. Got the Time slip to prove it. And that's with a 2 1/2" Catback with a flowmaster 80 series, dual outlets... GMS Airbox Factory Air silencer deleted (heh, Home Depot PVC pipe helped as a cheap mod..), and K&N filter. I consider myself lucky if I've picked up 5hp and 8ft/lbs from stock. However, it is a 3.8 V6, and will probably not yield as much gains as an LT1 or L98 has.
LB985IROC
PostPosted: Wed Dec 20, 2006 4:17 pm    Post subject: Reply with quote
ok ok i found the slips for my iroc i was way off but it still ran a 15.1 not sure on the speed couldnt read it i think it says 88 mph and that was launching in overdrive with poor traction and for the record i checked the numbers and the motor i had was from a 60s camaro wiht 2.02 camel hump heads
Retail parts sales
vee-six
PostPosted: Wed Dec 20, 2006 5:00 pm    Post subject: Reply with quote
That sounds more like it.
Tanking off in OD doesn't matter. The trans is still in first with all the clutches.
Camel humps were awesome for their day!
Post new topic   Reply to topic    Cascade Crew Forum Index -> Event Calendar All times are GMT - 8 Hours
Page 4 of 10
