![](images/avatars/21314728524a29e0c1b5cf2.jpg)
Posted: Fri Sep 29, 2006 9:52 am Post subject: V6 Hydrolic T-5 |
I want a V6 T-5 with Hydrolic bell housing. If you have one you want to part with let me know! I could modify a WC-T5 (I ownone ) to fit if you want to sell me a blown T-5 with the above requirements.
Thanks! _________________ E30
![](images/avatars/19028298594664fbf95f06b.gif)
Posted: Fri Sep 29, 2006 11:03 am Post subject: |
the belhousings actualy seperate from the tranny case, so all you realy need is the belhousing then right? |
Posted: Fri Sep 29, 2006 12:06 pm Post subject: |
the cases mount identical, but the input shaft on the V8 is 26 spline or whatever, so the input shaft would have to be swapped. Plus the gearing is a little different. So I could use a V6 hydrolic bellhousing as well, plus the flywheel and clutch. You have? |
Posted: Fri Sep 29, 2006 1:01 pm Post subject: |
no i don't. i was just trying to figure out what it is you need.
but i am confused. you have a v6 tranny on the car now with a hydrolic bellhousing correct? and you have a v8 trannsmission you want to bolt on to the car? you can bolt a v8 t5 to a v6 bellhousing. the tranny bolt patterns are the same. it is only the bellhousing to block pattern that is different. (and the splin/input shaft of course).
so why do you need a new bellhousing? |
Posted: Fri Sep 29, 2006 2:25 pm Post subject: |
I have a V6 automatic! Lol!
Here's the parts I own.
V8 WC-T5
S10 V6 cable T5
2ea 700r4's
The S10 V6 case wont work. Bellhousing is cable. No go. So, i need a V6 camaro T5 with a hydrolic bellhousing, OR, i can mate a hydrolic V6 bellhousing to the WC-T5. Make sense? |
PonchoTA Member
Posted: Fri Sep 29, 2006 3:07 pm Post subject: |
I have a T-5, V6 bellhousing, with the ear for the hydraulic clutch if that's what you need...
PM me! _________________ Paully |
Posted: Sat Sep 30, 2006 1:09 am Post subject: |
ohhhhh...... ok i understand now. |
wanarunhard Member
Joined: 11 May 2006 Posts: 125 Location: ellensburg wa
Posted: Sun Oct 29, 2006 12:09 am Post subject: v6 |
k i have a v6 5speed i think im going v8 with mine wanna swap?
i need v8 hyd trans have pressure plate and all mine is hyd |
