Posted: Tue Aug 15, 2006 10:38 am Post subject: Welding SFC's |
I'm putting my SFC's in tomorrow, but I wanted to know if I should weld the SFC's to the floor pan? I see a bunch of SFC's sold that only get welded at the stock subframes. My worry is that I'll blow a hole in the floor because the metal is thinner there. The kind I got are the straight 2" square tube that bolt in at the tranny x-member, and then get cut to length. Made by Competition Engineering. I've been told they will work great (maybe overkill for my V6). I just had that one concern. Thx! _________________ E30
Posted: Tue Aug 15, 2006 11:02 am Post subject: |
| Mine are welded to the length of the SFC's along the floor. It is a stitch weld, so there is about a 2" bead, then a 2" break, then 2" bead, etc. |
Posted: Tue Aug 15, 2006 11:22 am Post subject: |
Did you weld both sides of the sfc's? I'm going to pay special attention to the subframe area's and seam weld the subframes as well as I can.
I'm assuming your sfc's are straight, so what did you do to get it around the rear seat bumps? Last I checked, they get in the way of the straight shot between the front and rear frames. I'm thinking it would be best to pound any obtrusion up instead of cutting a channel out and welding it closed.
I've owned these sfc's for over a year but they require custom exhaust. Now that i have custom exhaust, game on. |
Posted: Tue Aug 15, 2006 11:24 am Post subject: |
| I have Spohn SFCs, they are fitted to the floor pan. The pass side one is shaped to fit the floorpan. |
Posted: Tue Aug 15, 2006 11:38 am Post subject: |
| i see. Mine aren't like that at all. I'll post pics of the finished porduct. |
Posted: Tue Aug 15, 2006 11:43 am Post subject: |
Here is how mine fit. It is probably hard to see the welds along the floor pan though.
Posted: Tue Aug 15, 2006 11:49 am Post subject: |
| yup, mine bolt right where yours welds to the tranny mount bolts and goes straight back, no bends. |
Posted: Tue Aug 15, 2006 11:53 am Post subject: |
| Just weld the stiches on the inside of the car on the sfr along the floor. Make sure you pull your carpet back! Hmmmm bolt it at those bolts i dont like. They are already notorious for stripping. |
Posted: Thu Aug 17, 2006 7:05 am Post subject: |
| Bad juju. The connectors I got are the Ghetto Fabulous ones. There is no way to make them fit, unless they get hacked up. They are straight, and it is not a straight shot by a long ways. I'm going to sit on it for a bit. Bum deal. |
Posted: Thu Aug 17, 2006 2:45 pm Post subject: |
| My Kenny Brown SFC's installed the same as Dewey's. |
