85 trans am
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Tue Aug 01, 2006 10:06 am    Post subject: 85 trans am Reply with quote
Well I found a 85 trans am with a rear disk and manual tranni, it was a 350 car, that’s what he is saying.
Is this car anything special as far as the rear is concerned? Must be a series three carrier???
Maybe 373 gears stock??
Why would a 85 trans am have a 350 and rear disk????
Kind of old side for that stuff isn't it, to be stock equipment?
Do you think its posi??
I just want the rear and tranni maybe.....
Thanks
Scott
PostPosted: Tue Aug 01, 2006 10:12 am    Post subject: Reply with quote
I don't think there were any 350's in 85. Get the vin number, that will tell you what motor it had stock. No way to know the gears without the RPO sheet, but more likely 3.23 or 3.08, or 2.73, 3.42 if you are lucky. Unless he changed them, i strongly doubt it is a 3.73 rear.
-John
PostPosted: Tue Aug 01, 2006 10:45 am    Post subject: Reply with quote
Quite a few of the older L69 5 speed firebirds were 9-Bolt 3.70 rears (wasn't Barts firebird 3.70 w/disc?).
Definitely wasn't a factory 350/5 speed car though. That has been beat to death.
PostPosted: Tue Aug 01, 2006 10:52 am    Post subject: Reply with quote
Barts car was modified by Paul. It was 1LE disk, 3.73 10bolt with an aftermarket Posi.
scott in wa.
PostPosted: Tue Aug 01, 2006 11:23 am    Post subject: 9 bolt Reply with quote
Thats that Ausi rear, thats hard to find parts for right.
I will have to get the VIN.
scott in wa.
PostPosted: Tue Aug 01, 2006 12:05 pm    Post subject: VIN NUMBER Reply with quote
1G2FW87G7FL622777
OK here it is.
where do I go to look it up?
thanks
scott
oh I got it.
what does the G = 305 CID, 5.0L, V8 BC (BC mean)
PostPosted: Tue Aug 01, 2006 1:56 pm    Post subject: Reply with quote
G = L69, so you got the HO 4-barrel. Dunno where you got that BC code, but it might mean a carbed car as opposed to the LB9 TPI engine.
Other than that, the VIN decoder says it all checks out as an '85 Trans Am out of Van Nuys.
Oh and TGO says that the '85 L69 w/T-5 did actually come with 3.73's:
http://www.thirdgen.org/1985-pontiac-firebird
BTW, I use this decoder: http://www.geocities.com/fbodyvin/
You need the .NET framework, so you'll either need to download it, or upgrade your XP service packs.
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Tue Aug 01, 2006 5:53 pm    Post subject: Reply with quote
If its an HO car then it has a 3:70
T/A's w/L69, stick & G92=Very Rare!
Add WS6 and you have a collector
I have one Cool
If you saw disks it may very well be a WS6 car, rear discs were std in 85 with the WS6
Here is a rundown on the 9bolt, scroll down, great info
http://www.automotivehelper.com/topic414786.htm
An LB9 would come with a 3:27, got one of those too Very Happy
PostPosted: Tue Aug 01, 2006 5:56 pm    Post subject: Reply with quote
Dude, slap that T-5 and those gears behind the Z28's engine with an HSR, and it would be one hell of a lethal combo. Thumbs up
PostPosted: Wed Aug 02, 2006 7:35 pm    Post subject: Reply with quote
I'm with stupid
if he's selling the whole car, it might be worth taking the whole thing. (..I just am not a convertable fan..)
PostPosted: Wed Aug 02, 2006 7:55 pm    Post subject: Reply with quote
Quasi-Traction wrote:
I'm with stupid
I've actually seen the car Scott is working on, and trust me, he's keeping that one. Wink It's in excellent shape.
PostPosted: Wed Aug 02, 2006 9:56 pm    Post subject: Reply with quote
Shocked Blasphemy! Laughing
PostPosted: Wed Aug 02, 2006 10:33 pm    Post subject: Reply with quote
its a common option for the t/a's between 83 and 87 i have that on my 84 and i also have a spare axel aswell even lagion is selling a 84 ws6 that is exactly like mine down to the color.
