the yellow TA - status
miamivice
1982 Pontiac Trans Am
PostPosted: Wed Jul 26, 2006 10:20 pm    Post subject: the yellow TA - status Reply with quote
....is still broke, doesnt look like it will be making an apperance at the gathering this weekend. still up on jackstands, last weekend the broken flexplate came out and new one went in and the tranny was put back in place. but, whats left is for all the bolts to go back in, all the linkage, electrical connections and other lines to be hooked back up
also, starter needs to go back, drive shaft, and then put in the new injectors, reprogram the computer, and check for any vacuum leaks.
fun huh? Yup yup
Bashy Bashy
miamivice
PostPosted: Wed Jul 26, 2006 10:22 pm    Post subject: Reply with quote
oh yeah, does anyone happen to have a TV cable for a 700r4 trans hooked up w/ a 305 tpi. thats the only part we dont have to finish up the car.
PostPosted: Thu Jul 27, 2006 12:45 am    Post subject: Reply with quote
dang... if i had known you needed it i would have been more carefull. i cut mine getting it out.
PostPosted: Thu Jul 27, 2006 9:32 am    Post subject: Reply with quote
Do they sell those as a replacement item anywhere, or is it an eBay/boneyard item?
PostPosted: Thu Jul 27, 2006 10:56 am    Post subject: Reply with quote
Dealer/JY only. I called every single parts warehouse I could. Most of the wholesale places as well. It's not even a part that ACdelco makes for GM dealerships like most other parts. GM's got it. And luckily, a stealership in tacoma here (gilcrest) had one.
I hate sporatic schedules.
Mangus
1989 Pontiac Trans Am
PostPosted: Thu Jul 27, 2006 12:19 pm    Post subject: Re: the yellow TA - status Reply with quote
The TV may be the only real hassle. Electical connections will take you 5 minutes, starter will take you 15. Bolts (Depending on which bolts) should be simple (there aren't that many). Linkage is simple. The injectors you have function (if I recall correctly), although they need replacement (as you know, I have that part down to a science). Everything you listed there, minus the injectors, is like 3 hours of work and pretty simple, even for a auto-mech newbie! Make it happen! Smile
We can't have you and Ian both flake on your own damn gathering.
PostPosted: Thu Jul 27, 2006 1:20 pm    Post subject: Reply with quote
Get 'r' done buddy - need more firebirds at this gathering Wink
TecherB
Princess B
PostPosted: Thu Jul 27, 2006 3:27 pm    Post subject: Reply with quote
Just put a little bit more time in to it just one more day of easy work and your done. if you cant figure something out ask ane well try to help. just put the little bit of time in to it and your driveing it to a gathering.
Doh!
"He looks like Donky Kong from Mario Kart."
PostPosted: Thu Jul 27, 2006 7:05 pm    Post subject: Reply with quote
I have a brand new 700r4 TV cable for TPI in the box
PostPosted: Thu Jul 27, 2006 8:02 pm    Post subject: Reply with quote
I have one but mine's for a carburated car....... I think it actually mounts in the same way.....but I'll have to get back to you on that. I probably won't ever use it....so if you want I can pull it and give it to someone going up to seattle and you can test it out. If it doesn't work you can chuck it in the garbage.
Mangus
PostPosted: Fri Jul 28, 2006 12:43 pm    Post subject: Reply with quote
Hey, maybe some of the other guys could show up to your place saturday morning and help you get it running. Should be totally possible to get you going in time for lunch.
