miamivice Member
1982 Pontiac Trans Am
Posted: Wed Jul 26, 2006 10:20 pm Post subject: the yellow TA - status |
....is still broke, doesnt look like it will be making an apperance at the gathering this weekend. still up on jackstands, last weekend the broken flexplate came out and new one went in and the tranny was put back in place. but, whats left is for all the bolts to go back in, all the linkage, electrical connections and other lines to be hooked back up
also, starter needs to go back, drive shaft, and then put in the new injectors, reprogram the computer, and check for any vacuum leaks.
fun huh?
miamivice Member
Posted: Wed Jul 26, 2006 10:22 pm Post subject: |
| oh yeah, does anyone happen to have a TV cable for a 700r4 trans hooked up w/ a 305 tpi. thats the only part we dont have to finish up the car. |
Posted: Thu Jul 27, 2006 12:45 am Post subject: |
| dang... if i had known you needed it i would have been more carefull. i cut mine getting it out. |
Posted: Thu Jul 27, 2006 9:32 am Post subject: |
| Do they sell those as a replacement item anywhere, or is it an eBay/boneyard item? |
Posted: Thu Jul 27, 2006 10:56 am Post subject: |
| Asdfga3 wrote: | | Do they sell those as a replacement item anywhere, or is it an eBay/boneyard item? |
Dealer/JY only. I called every single parts warehouse I could. Most of the wholesale places as well. It's not even a part that ACdelco makes for GM dealerships like most other parts. GM's got it. And luckily, a stealership in tacoma here (gilcrest) had one.
I hate sporatic schedules. _________________
Mangus Member
Joined: 10 Jan 2004 Posts: 255 Location: @computer in garage (Bothell)
1989 Pontiac Trans Am
Posted: Thu Jul 27, 2006 12:19 pm Post subject: Re: the yellow TA - status |
| miamivice wrote: | ....is still broke, doesnt look like it will be making an apperance at the gathering this weekend. still up on jackstands, last weekend the broken flexplate came out and new one went in and the tranny was put back in place. but, whats left is for all the bolts to go back in, all the linkage, electrical connections and other lines to be hooked back up
The TV may be the only real hassle. Electical connections will take you 5 minutes, starter will take you 15. Bolts (Depending on which bolts) should be simple (there aren't that many). Linkage is simple. The injectors you have function (if I recall correctly), although they need replacement (as you know, I have that part down to a science). Everything you listed there, minus the injectors, is like 3 hours of work and pretty simple, even for a auto-mech newbie! Make it happen!
We can't have you and Ian both flake on your own damn gathering. |
Posted: Thu Jul 27, 2006 1:20 pm Post subject: |
Get 'r' done buddy - need more firebirds at this gathering
TecherB Princess B
Posted: Thu Jul 27, 2006 3:27 pm Post subject: |
Just put a little bit more time in to it just one more day of easy work and your done. if you cant figure something out ask ane well try to help. just put the little bit of time in to it and your driveing it to a gathering. _________________
"He looks like Donky Kong from Mario Kart." |
BigDaddyVu 12sec Club
Posted: Thu Jul 27, 2006 7:05 pm Post subject: |
I have a brand new 700r4 TV cable for TPI in the box _________________
Posted: Thu Jul 27, 2006 8:02 pm Post subject: |
| miamivice wrote: | | oh yeah, does anyone happen to have a TV cable for a 700r4 trans hooked up w/ a 305 tpi. thats the only part we dont have to finish up the car. |
I have one but mine's for a carburated car....... I think it actually mounts in the same way.....but I'll have to get back to you on that. I probably won't ever use it....so if you want I can pull it and give it to someone going up to seattle and you can test it out. If it doesn't work you can chuck it in the garbage. _________________
Mangus Member
Posted: Fri Jul 28, 2006 12:43 pm Post subject: |
| Hey, maybe some of the other guys could show up to your place saturday morning and help you get it running. Should be totally possible to get you going in time for lunch. |
