POSI/LSD
PostPosted: Fri Jul 21, 2006 6:50 am    Post subject: POSI/LSD Reply with quote
If anyone can help out that would be awesome. I have 4.11 gears in my garage that I want to put in, but I don't want to without some sort of traction control. Are drum axle, 3-series, LSD units hard to come by? I've been looking around for a long time and noone seems to have any for sale. If I can't find one soon I'll have to buy new. Any suggestion or offers?
PostPosted: Fri Jul 21, 2006 4:28 pm    Post subject: Reply with quote
For the posi unit drum or disc doesn't matter if that helps your search. Spline count on the axles matters though, if you have an 89 you could have 26 or 28 spline axles I believe.
PostPosted: Sat Aug 19, 2006 9:39 am    Post subject: Reply with quote
So it turns out I need a 26 spline, 3-series LSD carrier.
PostPosted: Sat Aug 19, 2006 2:37 pm    Post subject: Reply with quote
What the hell is an LSD posi?
Like... you go auto cross and have hallucinations about posi?
PostPosted: Sat Aug 19, 2006 2:53 pm    Post subject: Reply with quote
http://en.wikipedia.org/wiki/Limited_slip_differential
Get down and Boogie!
I like your explanation better though.
PostPosted: Sat Aug 19, 2006 2:55 pm    Post subject: Reply with quote
Ahh didn't realize LSD was an acronym for Limited Slip.
Limited Slip is a GM term Wink
PostPosted: Sat Aug 19, 2006 2:56 pm    Post subject: Reply with quote
Posi-tractrion is just a "GMism" for a clutch type Limited Slip Differential or LSD. there are three types of LSD; clutch, viscous and helical.
PostPosted: Sat Aug 19, 2006 2:59 pm    Post subject: Reply with quote
And Torsen!^ Actually there are tons of different kinds of "posi/limited slip"
As far as I know "limited slip" is a GM term. Everyone else calls them positraction. Hense GM's additive called "Limited Slip Oil Additive."
PostPosted: Sat Aug 19, 2006 3:07 pm    Post subject: Reply with quote
WRONG!!!!
Posi traction is chevy's.
Limited Slip is Ford's
I really dunno, just wanted to yell at Paul. Embarassed
PostPosted: Sat Aug 19, 2006 3:10 pm    Post subject: Reply with quote
Pokey pokey Read the link....
Factory Names
In the 1950's and 1960's many manufacturers began to apply brand names to their LSD units. The most famous of these was Chevrolet's "Positraction". Since then, Positraction (often shortened to "positrac" or merely "posi") has become a genericized trademark for LSDs.
Other factory names for LSD's include
Pontiac: Safe-T-Track
Ford: Equa-Lock and Trac-Lok
American Motors Corporation: Twin-Grip
Mopar: Sure Grip
Ferrari: E-Diff
Fiat: Viscodrive
PostPosted: Sat Aug 19, 2006 5:43 pm    Post subject: Reply with quote
You do know that I could post on Wikipedia that the sky is red... and it'd be there.... It's not credited information
PostPosted: Sat Aug 19, 2006 7:10 pm    Post subject: Reply with quote
I know. But then again most everything on the internet isn't.
PostPosted: Sun Aug 20, 2006 11:58 am    Post subject: Reply with quote
my brother uses "limited slip" when talking about toyotas, BMWs and Nissans... i had always figured it was the "official" term.
PostPosted: Sun Aug 20, 2006 10:08 pm    Post subject: Reply with quote
I always kind of figured that "limited slip" was just a generic term for anything that will have two wheels turning on any manufacturers car.
I always thought each manufacture had there own cute little name for it (IE, chevy: Positraction, Ford: Equa-lock, Mopar: Sure-grip.)
oh well. Rolling Eyes
PostPosted: Sun Aug 20, 2006 11:10 pm    Post subject: Reply with quote
Me too.
PostPosted: Sun Aug 20, 2006 11:11 pm    Post subject: Reply with quote
Dang........when I saw the "LSD" thing I thougth I was having flashbacks to the 60's Wink
LSD was the term for "Lysergic acid diethylamide" One of those "mind altering drugs we had back then.
PostPosted: Mon Aug 21, 2006 8:18 am    Post subject: ENOUGH BS Reply with quote
Now that we all are on the same page...
Back to my post. Like I said before, I'm looking for some kind of traction control. The rear end in my car is a GM 10bolt that will accept 26 spline 3 series carriers. If anyone has anything that will fit back there I would greatly appreciate it if it was for sale. What I don't want is a 2 series commonly found on IROC's or other V8 cars.
PostPosted: Mon Aug 21, 2006 5:19 pm    Post subject: Reply with quote
2 series carrier is fine if you use a ring gear spacer. There about $40 - $50 . If you got a smoking deal on a two series it would be worth it.
PostPosted: Tue Aug 22, 2006 6:53 am    Post subject: Reply with quote
I'm slowly learning about camaro axles...
A stock GM 10 bolt camaro axle is a 7.5" right, not 7 5/8"? I have a 2 series LSD at home, but I hadn't known it would work until I just found out the spline count are the same. I'm going to track down a spacer and get it.
PostPosted: Tue Aug 22, 2006 1:08 pm    Post subject: Reply with quote
Make sure the spacer comes with bolts. Sounds stupid but the ringgear bolts are left hand thread 7/16's fine thread. You can not just buy them.
I got a "deal" on the first ring gear spacer I bought and figured I'd just run down to the hardware store and get some longer bolts. Embarassed
BTW, I have a spacer for sale.
Just needs bolts. Laughing
