'88 IROC and other stuff/parts
Brisk
PostPosted: Sun May 07, 2006 2:20 pm    Post subject: '88 IROC and other stuff/parts Reply with quote
'88 IROC, BC Car. TPI LB9 305 T-5, T-tops (don't leak) Leather power seats, fully loaded (no A/C). Tons of new parts within the last 2 years, including but not limited to;
new starter
new alternator
new water pump
new battery
new serpentine belt
new computer
new chip
new exhaust (cat back, removed cat)
used door panels
used door panel plastic tops
used door pulls
used power locks
used sill panels
used sail panels
used rocker panels
used dash pad
used steering wheel
used power hatch motor
& cleaned/flushed out radiator
(used parts in excellent condition)
T-Tops do not leak. Car is strong and pulls hard throughout the RPM range. Drives straight, looks straight, rust free. Esentially stock except for the exhaust. Needs a paint job.. I mean doesn't absolutly need it, but it looks flat black at the moment.. cheap-o Macco paint job from years ago.
Little bit of puffing on start up, needs valve seals.. and needs a MAF burn-off relay. Bought a mint car with low miles so this one has to go. Asking $3500 Canadian OBO and it can be arranged to be delivered into Washington state.
Other stuff for sale; (prices OBO, plus shipping)
-scosche camaro cd player install bracket, new. - $5
-triagnle window seals, one for left and one for right. not greatest, but don't leak - $5
- 34mm hollow front sway bar from IROC. $20
- 3 x 22mm soild rear sway bars from IROC. $20 each
- complete drum to drum rear end from a '88 IROC with 49,000 original miles. 3.08 ratio with posi and drum brakes. Rear diff cover has never been off, mint. (I may not have the means to ship this... so local pick-up only unless I can figure out how to crate and ship this) $200
- Comp Cam 987-16 Springs, 740-16 retainers, 613-16 locks. New and never used. Bought them but they're wrong for my application. I'm into them for $200US plus shipping, make an offer
- ADS Super Chip part # 8819 A and my stock chip which is part # AKFT 2389. These chips came out of my '88 IROC with a 305 TPI and 5-speed transmission.This is a piggy back chip, it plugs into your computer and your stock chip plugs in ontop of the ads chip. $50
- one left and one right power lock acutators/motors for power locks. These are in great shape and have minimal play when fully extended. $10
- stock panhard bar. Make offer.
- pair of axles, I believe they're 26 spline. $50
- Bilstein shock take-offs, still in good shape. $25
- stock IROC springs.. not sure if these will hit the for sale pile yet but I'll post them up in here.
- one pair (mabey two pairs) aluminum brake drums.. plenty of meat left. $40/pair
For more info or pics email me; iroczee@gmail.com
90droptoproc
PostPosted: Sun May 07, 2006 9:39 pm    Post subject: Reply with quote
how much are you looking for the rad?
I am in langley, where are you located I might be interested in the rear from the iroc
Rich
Brisk
PostPosted: Mon May 08, 2006 9:53 am    Post subject: Reply with quote
I am in Castlegar located in the West Kootenay's.
The rad listed is in the car which is for sale, sorry.
Brisk
PostPosted: Sat May 13, 2006 2:42 pm    Post subject: Reply with quote
Car is sold, thanks for all inquires.
Parts listed are still avaliable.
Brisk
PostPosted: Sun May 21, 2006 9:50 pm    Post subject: Reply with quote
SOLD - Comp Cam 987-16 Springs, 740-16 retainers, 613-16 locks. New and never used.
