Valve cover gaskets
Gibby85
PostPosted: Fri Apr 28, 2006 11:06 am    Post subject: Valve cover gaskets Reply with quote
Where's a good place for price to match my stock valve covers. I need new gaskets as one is leaking. I'm not concerned with replacing the whole covers, just the gaskets.
Thanks.
www.cardomain.com/id/gibbys85
PostPosted: Fri Apr 28, 2006 11:07 am    Post subject: Reply with quote
Just go to schmucks, napa, or whatever. Valve cover gaskets are dirt cheap.
Gibby85
PostPosted: Fri Apr 28, 2006 11:18 am    Post subject: Reply with quote
Cool. Never bought a set so didn't know how readily available they are. Thanks.
PostPosted: Fri Apr 28, 2006 12:41 pm    Post subject: Reply with quote
Buy rubber ones. You'll be able to reuse them. They are around $20
PostPosted: Fri Apr 28, 2006 1:16 pm    Post subject: Reply with quote
Ditto to that. NEVER buy the cork kind. They crap out on you like that.
PostPosted: Fri Apr 28, 2006 1:59 pm    Post subject: Reply with quote
Actually that's not true. I've had my tall valve covers for almost two years now and replaced the cork gasket once. Mind you, I've had the valve covers off close to 100 times for adjustments, and fitment things.
All you have to do is gaskecinch the cork to the valve cover, and then line the other side of the cork with vaseline. Seals great, and comes right off. I have to use cork with the tall valve covers, because the rubber isn't thick enough. Napa Metal center cork on each side gaskets.
PostPosted: Fri Apr 28, 2006 3:40 pm    Post subject: Reply with quote
The metal center ones might not be bad. The ones I've had problems with in the past seemed to be all cork.
Gibby85
PostPosted: Tue May 02, 2006 9:04 am    Post subject: Reply with quote
Thanks gents.
