How would our motor run if?
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Mon Apr 24, 2006 8:36 am    Post subject: How would our motor run if? Reply with quote
Iam playing with the idea of taking the built motor out if the 87z TPI and putting it into the 88TBI car, Can I Run the big cammed motor with a TBI intake on top of it?
How would it run
What kind of mods would have to be done?
thanks
scott
PostPosted: Mon Apr 24, 2006 8:54 am    Post subject: Reply with quote
It takes some work with the computer. How big of a cam are you talking, and on how big of a motor? Best bet with TBI, is to get a carb single plane intake, then an carb to TBI adaptor plate, and use that.
scott in wa.
PostPosted: Mon Apr 24, 2006 9:10 am    Post subject: hefty Reply with quote
350 .060 over small chamber 305 HO heads, 52cc, ported, put big stainless valves in, had to bore out some of the side walls in heads so its a bit more than 52 now.
74 cc dished pistons
Around 10/1 compression.
Lt4 hot cam roller, 1.5 stainless roller rockers
useing 26lb injectore in the tpi.
took alot of work to get it to run Ok, as far as the computer goes.
there was alot of help from a few people here on the programming.
But was thinking about running it in the TBI, just do a intake swap.
will it run???
thanks
scott
PostPosted: Mon Apr 24, 2006 9:19 am    Post subject: Reply with quote
You are going to need bigger TBI injectors. It is going to also take a significant amount of programing. You might be better off swaping in the TPI computer, instead of reusing TBI on that motor.
scott in wa.
PostPosted: Mon Apr 24, 2006 10:40 am    Post subject: yep Reply with quote
Ya thats what I thought.
The kid wants that other motor in, But I have been telling him NO, not yet.
Maybe in the fall. Seeing how gas is way up there.
The TBI are MAP correct?
Id rather not do all the crying about how I can't get the car running to you guys anyway (again). At least the TPI set now runs OK...
He will have to wait.
thanks
scott
PostPosted: Mon Apr 24, 2006 1:37 pm    Post subject: Reply with quote
Yes, TBI is a MAP system, Paul and I have a good amount of experiance tuning TBI, We could probably help you get it running. But I think you would be happier with MPI on that system, instead of TBI.
PostPosted: Mon Apr 24, 2006 2:48 pm    Post subject: Re: How would our motor run if? Reply with quote
Why? Confused
PostPosted: Mon Apr 24, 2006 7:17 pm    Post subject: Re: How would our motor run if? Reply with quote
QwkTrip wrote:
Why? Confused
His 87's been wrecked and the 88 is a vert.
PostPosted: Mon Apr 24, 2006 8:47 pm    Post subject: Reply with quote
Save the money... get a commander.
I'll say it till I'm blue in the face.
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Mon Apr 24, 2006 9:39 pm    Post subject: Reply with quote
too bad its not like hondas where you can flip flop parts all over the place in like 2 seconds lol but you should be able to swap the whole harness and the ecu from car to car
Cadillac of Bellevue
Retail parts sales
vee-six
PostPosted: Tue Apr 25, 2006 7:58 pm    Post subject: Reply with quote
Well, heck! I have a Holley Pro-Jection 4Di digital system that I've been trying to sell for years! 4-barrel throttle body 900 cfm. Rated for engines between 350Hp and 500Hp. I recommend at least 400Hp. I only used it for about 200 miles on my '68 El Camino before I parked it forever. The system is in the box and ready to go except for needing a new O2 sensor, only because the threads were cross-threaded by the monkey that installed it. Also, I changed the fuel ports from the barbed hose fittings to -AN fittings (much better).
PM me if you are interested. It's not the latest gizmo you can buy but it's good enough and won't empty the wallet as bad.
Jon
