Red Bird Member
1991 Pontiac Firebird
Posted: Mon Feb 20, 2006 1:44 pm Post subject: T-5 world class or not |
Hey i just fragged my tranny after an autocross. I am looking for a replacment so i can race again next month while getting the broken one rebuilt. Can anybody help me out? willing to come and pick up just about anywhere in the NW |
BigDaddyVu 12sec Club
Posted: Tue Feb 21, 2006 8:26 pm Post subject: |
Convert to a t-56 spd. Are you looking for a t-5 for a v8 or the v6? you can use the t-5 from a v6 to a v8 just buy a the disc that matches your splines or have one custom made to match the dia. of the v8. i've seen people use the stock 2.8l disc with there v8 pressure plate and it works great. i know a guy that has one right now and it is in great working order. _________________
Red Bird Member
Posted: Tue Feb 21, 2006 8:46 pm Post subject: |
I would need a v8 tranny. I would not want to put a t-5 from a v6 car in, I think they would be weaker than the the 8 cylinder tranny, and i abuse the hell out of it while autocrossing, and driving wreckless lol |
Posted: Fri Feb 24, 2006 6:12 am Post subject: |
there the same except the input shaft _________________
Posted: Fri Feb 24, 2006 7:48 am Post subject: |
Red Bird wrote: | I would need a v8 tranny. I would not want to put a t-5 from a v6 car in, I think they would be weaker than the the 8 cylinder tranny, and i abuse the hell out of it while autocrossing, and driving wreckless lol |
I would stick with the V8 tranny for the better spaced gear ratio's. The smaller input shaft and deeper 1st gear ratio are all that make the V6 trannys a little weaker than the V8 ones, but the gear ratios suck. |
Posted: Fri Feb 24, 2006 10:38 am Post subject: |
rjmcgee wrote: | Red Bird wrote: | I would need a v8 tranny. I would not want to put a t-5 from a v6 car in, I think they would be weaker than the the 8 cylinder tranny, and i abuse the hell out of it while autocrossing, and driving wreckless lol |
The input shaft is the same size, just larger and fewer splines. |
Posted: Fri Feb 24, 2006 11:10 am Post subject: |
Twilightoptics wrote: | The input shaft is the same size, just larger and fewer splines. |
soooo... completly different is what you are saying? |
Posted: Fri Feb 24, 2006 11:29 am Post subject: |
Xophertony wrote: | Twilightoptics wrote: | The input shaft is the same size, just larger and fewer splines. |
No. Completely different would mean it has a different size pilot bearing, spline count different yes, length different.
All that is different is the spline count. You get get a disc made for a V6 trans. I've done it.
Last edited by Twilightoptics on Fri Feb 24, 2006 1:51 pm; edited 1 time in total |
Posted: Fri Feb 24, 2006 12:47 pm Post subject: |
you have to admit that is confusing especialy when i have no idea what i am talking about |
Posted: Fri Feb 24, 2006 12:51 pm Post subject: |
the input shaft is the same size.
The diffrence is in the number and size of the splines. The V8 has more, but smaller sized splines. The V6 has fewer, but larger splines. |
Posted: Fri Feb 24, 2006 1:32 pm Post subject: |
I thought the V6 tranny had a 1" 14 spline input shaft.
The V8 has a 1 1/8 28 spline input shaft. |
Posted: Fri Feb 24, 2006 1:51 pm Post subject: |
rjmcgee wrote: | I thought the V6 tranny had a 1" 14 spline input shaft.
You're right.
But the pilot bearing part of the shaft is the same. |
Red Bird Member
Posted: Fri Feb 24, 2006 9:30 pm Post subject: |
Still lookin for one. Any leads on finding one would be awesome. |
Red Bird Member
Posted: Wed Mar 15, 2006 10:37 pm Post subject: |
Well Still havent got any replys, If you got a V-6 T-5 hit me up i just need to get the car operational. |
Posted: Sun Apr 16, 2006 1:10 pm Post subject: |
If the motor in my 84 is bad (#4 was getting no compression) I'll sell you the T-5 out of it for $75. do you need the shifter also? _________________
Red Bird Member
Posted: Sun Apr 16, 2006 5:30 pm Post subject: |
I would just need the tranny, i dont think i need the shifter unless i would not be able to re-use the one that is in the car already. I am waiting on a guy who said he has one on TGO. but let me know if ur motor is bad, i havent heard back from him in a while. |
Posted: Sun Apr 16, 2006 11:54 pm Post subject: |
will do. I'll probalby know by Tuesday. _________________
Posted: Tue Apr 18, 2006 6:23 pm Post subject: |
#4 sucked its exhaust valve. Not worth money/time to repair.
Tranny is yours.
Will you be at PWC in Skamokawa? If you need it sooner, I'll drain the fluid and see how much shipping will be.
I gotta limp it home tomorrow, then I can start pulling the Tranny.
This is the earlier type that takes the 80w gear oil and not GM syncromesh. _________________
Posted: Tue Apr 18, 2006 8:31 pm Post subject: |
If he's not coming to Cows.. maybe one of the Spokanites could drop it off??? If he asks reaaally nice maybe?? LOL |
Posted: Wed Apr 19, 2006 12:36 pm Post subject: |
Eah, no big deal, I have a couple TV boxes and I could wrap it pretty good. Someone told me that these things don't weight that much without gear oil in them, like 35-45lbs. I guess I get to find out, huh? _________________
