Posted: Sun Nov 27, 2005 2:11 pm Post subject: Window cranks, Driver door pannel, non PL and PW console |
the post doesn't lie, I am looking for those things......
I need the driver and pass window regulators for manual windows
I also need a Grey driver and passenger door pannel that is cut for crank windows
and the center console w/o clock, power locks or power window switches.
Also if someone has a delete plate for the stereo, that'd help too.....or knows someone who can make one that fits the 4 factory screws....you'd be the coolest crewbie ever... _________________
Posted: Sun Nov 27, 2005 6:53 pm Post subject: |
i can make that plate for you. it would be completly flat piece of plastic, slightly sloped at the bottom (for the angle change in the pod) with four holes drilled in it. i would use a sheet of plastic with factory style plastic pattern on it (think dashpad)
if you put your mind to it i am sure you could make somthing realy cool that would hold stuff. like a cargo compartment there... that would be cool. might also be a place to mount extra gages.. i can't do that stuff though.. i am just going to cut somthing out with a dremmle tool... do you want me to make one for you? |
Posted: Mon Nov 28, 2005 8:01 pm Post subject: |
most definately tony....I have kind of a template to start with, if you can do something like that, that'd be great. I can bring you the template tomorrow if you're available. $15 sound fair for time/labor/materials? _________________
