miamivice Member
1982 Pontiac Trans Am
Posted: Mon Feb 02, 2004 7:21 pm Post subject: where to go for instal |
were would i take my car to get sub frames welded on? i really have no clue, body shop? the frame rail is bent up a bit from the guy jacking the car up, so the place would need to be able to bang that back straight.
thanks. _________________
Posted: Mon Feb 02, 2004 7:34 pm Post subject: |
I doubt the frame rail is bent from jacking. You might be thinking of hte sheet metal that comes down.
Try an alignment shop, or a brake shop.... they might be able to point you in the right direction. |
PonchoTA Member
Posted: Mon Feb 02, 2004 7:45 pm Post subject: |
Most offroad shops can do it too. I know Randy's Offroad in Marysville will do it, but that's quite a ways for you to go. |
miamivice Member
Posted: Mon Feb 02, 2004 8:02 pm Post subject: |
Twilightoptics wrote: | I doubt the frame rail is bent from jacking. You might be thinking of hte sheet metal that comes down. |
yeah thats what it is, just couldnt think of what to call it _________________
Midnight Sun Member
Posted: Mon Feb 02, 2004 10:20 pm Post subject: |
If you are in no rush I could probably do it for in the June timeframe free of charge.
Other then that, I'd imagine just about any bodyshop would do it. There is a place next to the everett mall that I think would do it, and Evergreen Auto on Bothell Everett Highway. _________________
Posted: Tue Feb 03, 2004 3:55 am Post subject: |
the one really important thing, is make sure they lift the car by the wheels, not the frame. if the suspension is not loaded when they weld the SFC's in, it will cause all sorts of problems. |
