You know, I never started a project thread
Goto page Previous  1, 2, 3 ... 56, 57, 58
Jess
Administrator
PostPosted: Mon Jan 22, 2018 11:02 pm    Post subject: Reply with quote
QwkTrip wrote:
I wish I could display pictures here. Getting pretty dry just typing messages.
If you're not opposed to creating a Yahoo account, Flickr gives you 1TB of storage and allows embedding in other external sites/forums etc... Can even have the photos marked private and share/embed them with a 'guest pass' link so they are visible on the forum but not to the general Flickr user base.
Wish I could help you on the technical question, but thats over my head...
izcain
9sec Club
PostPosted: Tue Jan 30, 2018 10:16 am    Post subject: Reply with quote
Qwk,
That does seem a bit odd to me. but maybe not totally out in left field. Although .020+ is a bit of variance. I would imagine the difference is probably in the deck more then the crank centerline. Could always find that out though.
I have always measured the deck zero'd the dial and then took a reading on the level portion of the piston at tdc. There is always portions that are a bit under or over on the piston. I try to make sure I measure the exact same spot on all.
9.17 @ 148
PostPosted: Wed Jan 31, 2018 10:20 pm    Post subject: Reply with quote
Cool, thanks. That gives me confidence I did it right. Taking a measurement is simple. It's knowing how/what to measure that is key!
I talked with Mamo and the numbers didn't seem to bother him one bit. In fact, he agreed with my idea to run two different gasket thickness. Unfortunately, Cometic does not make the thickness we wanted for the short side (0.038) so we went with 0.040 gasket on both sides. It's not much of a difference either way but would have been nice if they had the thinner gasket available.
PostPosted: Mon Aug 20, 2018 4:43 pm    Post subject: Reply with quote
LS7 is done. Just need to decide when to drop it in the car. This will be a 600 WHP thumper with reasonable street manners.
* LS7 stock short block (4.125 bore, 4" stroke). Forged crank, lightweight titanium rods, lightweight cast aluminum pistons).
* Tony Mamo 265 heads (ported Trick Flow 260 LS7 heads) that flow 415 cfm. Yes, that's right.... 415 cfm from a 265 cc runner. Freakin' fantastic.
* Tony Mamo ported MSD LS7 intake. Nasty billet fuel rails to keep my current tall Bosch 650 EV14 injectors.
* Johnson low-travel link-bar lifters, Manton pushrods, Mamo Yella Terra 1.85 rockers.
* Comp Cams LSG lobe, 240/254 , 114+3 , 0.658 / 0.659
* Wet sump conversion. IWIS timing chain, Scoggin Dickey crankshaft spacer, Melling high pressure pump; Holley 302-1 oil pan (6 Qt); Improved Racing crank scraper, windage tray, trap door baffles.
* ATI damper, 10% under drive, fitted with 66 durometer rubbers.
The rest pretty much gets transferred over from my car.
izcain
9sec Club
PostPosted: Mon Aug 20, 2018 7:44 pm    Post subject: Reply with quote
Right on man, now this is exciting!
Can't wait to see numbers!
9.17 @ 148
PostPosted: Fri Aug 31, 2018 6:23 pm    Post subject: Reply with quote
Good lord man.
PostPosted: Wed May 08, 2019 8:31 pm    Post subject: Reply with quote
I got the car running a few weeks ago but I've been chasing down bad noises with various causes. Right now the passenger side cylinder head is removed and I'm waiting for new lifters to show up. Hopefully that will be the last of the noises.
This engine seems legit though. I've only touched the throttle once at part throttle and extremely mild timing (just 20 degrees) and it felt like it destroyed my old engine. The car was all over the road and so freakin' fast.
I thought my exhaust was loud before but now the car is stupid loud. And I do mean LOUD. Must be the higher compression or something. The noise is at "you're a problem" level now. I'll have to think about a catalytic converter or something to hush it some.
I hate the rebuilt clutch. It's awful. It's very grabby with almost no street friendly slip zone. I drove that clutch for 3 years and it was a bit tricky but now it's downright awful. I keep killing the engine or smoking the clutch. It's ridiculous and it makes it look like I have the skill of a 5 year old.
PostPosted: Sat Jul 06, 2019 9:09 pm    Post subject: Reply with quote
Still haven't tuned the engine yet other than drivability, which is pretty decent now. There's no point because the car is choking the engine from all sides: fuel, intake, & exhaust.
I've had a Boost-A-Pump on order for ages and still hasn't arrived. Hint: Don't ever buy anything from TPS Motorsports. That's all I will say about that.
The 4" intake is choking the engine. Getting a 3 kPA drop in MAP, maybe more, as the engine revs through its range. Not sure what the engine wants but I guess I'll step up to a 5" intake tube and see what happens. I'd like a real gentle transition to the 4" throttle body but I'm not seeing anything like that for sale. Anybody got ideas for that?
I'm considering going to a dual 3" exhaust. But first I am going to fix the intake and fuel issues and get a baseline dyno run to see how much power the existing 3.5" single exhaust is robbing. I'm not rushing to replace my existing exhaust unless I'm going to get a lot of gains.
I also raised the ride height of the suspension and lo and behold I suddenly have a lot more traction. I haven't even bothered airing down the new tires yet because they're working good! Must have been on the bump stops waaaaaaay more than I had thought. Still haven't tried to launch from a stop yet though.... That will be the real test. But if I'm hooking better on the roll, then it stands to reason I'll hook better off the line too. Heck, maybe I'll even go faster than a 2.0 second 60' time. LOL!
Page 58 of 58
