Posted: Wed Feb 18, 2015 10:03 pm Post subject: Found an interesting article on ignition |
Just found this ignition article. I've always heard that if you have an HEI there is no need to install a CD ignition system. This goes into the reasons why you maybe should. It also discusses coil selection when you have a CD ignition. The type of coil you select will even change the ignition timing and can be used as a tuning aid. But the effect isn't very noticeable with a stock inductive ignition.
http://www.hotrod.com/how-to/engine/ignition-coil-tech/ |
Posted: Wed Feb 18, 2015 10:59 pm Post subject: |
I had an MSD box with my HEI distributor on my ZZ4 El Camino. I just thought that was normal? |
Posted: Thu Feb 19, 2015 12:49 pm Post subject: |
That one is news to me as well. I think I see MSD boxes on HEI cars more than on anything else. I ran one on a DuraSpark with good success. |
