91camaro_rs Member
![](images/avatars/16244201154a82fd8aac78b.jpg)
Posted: Sun Sep 28, 2014 9:31 pm Post subject: colored hvac lines... |
ok guys im stumped. i never really paid attention to this until now... on the back of heater controls all the colored lines, the gray and purple split off and have a connection where they go to the firewall and purple goes to vacuum ball/vacuum source and gray goes out to heater control valve... what if i dont have the control valve or the vacuum ball what do i do? this makes me think to because im doing this for the 83 lsx..but my 91 doesnt have the ball or control valve either....any insight?? _________________
Posted: Sun Sep 28, 2014 9:34 pm Post subject: |
Both lines can be capped.
Do you have cruise on either car?
![](images/avatars/5331510654664d0c0e14ee.jpg)
Posted: Sun Sep 28, 2014 9:38 pm Post subject: |
And you must have the check valve or the vacuum ball will be useless. |
Posted: Sun Sep 28, 2014 9:42 pm Post subject: |
Yup.
Actually you need a check valve of some kind in the HVAC line with or without the reservoir to prevent the doors from reverting to default positions under throttle. |
91camaro_rs Member
Aaron no cruise on either car and non a/c as well. shouldnt the purple line at least go to a vacuum source? how do all the other colored ones get vacuum supply? _________________
Posted: Sun Sep 28, 2014 9:47 pm Post subject: |
Purple line needs to see manifold vacuum to shift the doors, and a check valve to keep them in place.
GM used the same check valve on every single vehicles for over two decades, just grab a couple at the yard. It's the cone-shaped three-way thing near the firewall.
The vacuum reservoir is for cruise control. GM did not use it for the solenoids like Ford did. |
91camaro_rs Member
Posted: Sun Sep 28, 2014 9:54 pm Post subject: |
ok so cap the gray one, purple to check valve and then to manifold easy enough!
now i gotta go look at the 91 tomorrow to see what the heck i did with that setup lol
as you might have been able to guess the 90's style dash swap is in progress in the 83 _________________
