need a bunch of odd parts !!
MrMike98
PostPosted: Fri May 16, 2014 2:56 pm    Post subject: need a bunch of odd parts !! Reply with quote
a very long story not suitable for this forum------however--------
a need the following parts:
1990 trans am gta hardtop
lower radiator air baffle _this pc bolts to bottom inside bumper cover
weather strip channel rails-A-pillar to roof-these hold the rubber seal-and screws.
hatch reinforcement plate-and all hardware---this is back of hatch-hatch glass is sandwiched between it and deck lid
outside mirrors-i have outer shells -i need internals i.e. motors, wiring and mirror glass and plastic gaskets for shell to door..
door vents and screws
that good for now.
thanks for any help
Mike
PostPosted: Sat May 17, 2014 8:40 am    Post subject: Reply with quote
Mike,
Would the hatch plate be the same on a 1991? I have a 91/982 hatch on the 86 firebird I am parting out. I could get you that plate if it will work.
When you say door vents, you meant eh two on the part of the door with the latch mechanism? If So I have those and the screws as well.
That plate would be a bit pricey to ship, will you be attending the Party With The Cows gathering?
PostPosted: Sat May 17, 2014 2:41 pm    Post subject: Reply with quote
Mike lives just down the road from me. I could transport parts from COWS for him, assuming they'll fit in the car...
