Posted: Sat Mar 15, 2014 12:07 pm Post subject: Jacob's ultracoil wiring help |
another classic tony move. I disconnected the wires from my ultracoil while moving some harness stuff around and now I cannot remember which wires go where. Anyone know which terminal gets the white wires, and which terminal gets the pink ones?
Thanks guys, I have scoured the google with no luck.[/i] |
Posted: Sat Mar 15, 2014 12:40 pm Post subject: |
found an old reference photo I made, unfortunately it is not too much help. turns out one wire of each color goes to each jacob's terminal. Crap. I have no idea which was where. |
Posted: Sat Mar 15, 2014 1:05 pm Post subject: |
Pink - power (+)
White - coil trigger from module (-) _________________ A redline a day keeps the carbon away! |
Posted: Sat Mar 15, 2014 1:24 pm Post subject: |
does that mean what I have photographed above is wrong? |
Posted: Sat Mar 15, 2014 1:41 pm Post subject: |
Positive and negative were also labeled on the bottom of the coil. |
Posted: Sat Mar 15, 2014 1:51 pm Post subject: |
Thanks Brandon! I'll pull it off it's mount now and have a look.
Paul,
To confirm, both pink wires should go to the same terminal, and both white wires to the other terminal? |
Posted: Sat Mar 15, 2014 1:56 pm Post subject: |
Correct. The pinks are both powers. One white is from the module to signal coil fire, the other is the lead to the tach. _________________ A redline a day keeps the carbon away! |
