Posted: Wed Aug 24, 2005 1:53 pm Post subject: Emission testing time! |
Failed it. Figured I would. I haven't gotten a chance to really do any good tuning time. Failed from too much HC (I was at 310, limit is 220). Anyone have any advice for things to do chip-wise? _________________
Posted: Wed Aug 24, 2005 4:16 pm Post subject: |
what test do they do? chances are you are going to need to take out some fuel, and maybe add some timing. Also make sure you cat is in good shape. |
Posted: Wed Aug 24, 2005 6:32 pm Post subject: |
Think it's a mostly stock car so do the usual.
Oil Change, Tune Up(plugs atleats), good gas (IE not arco), long drive before hitting the test station.
Did you fail at idle or cruise? |
Posted: Wed Aug 24, 2005 7:04 pm Post subject: |
Actually Arco is 10% alcohol. That should help hydrocarbon emissions. Also check the pump next time Paul, Arco stations are BP, which is also 76. You're basically gettin the same thing at all 3. Except for a small bottle of additive they dump in when they fill the station tanks. |
turbo_jimi Member
Posted: Wed Aug 24, 2005 8:13 pm Post subject: |
just do what i did...pay 150 in improvements and fail again and get a waiver...lol _________________
Posted: Wed Aug 24, 2005 11:54 pm Post subject: |
HSR 305 with the later lt1 cam
I just did plugs/wires/cap/rotor/pcv/fuel filter before I went.
Cruise was perfectly fine, even quite a bit under but idle was where I failed. It was just the sniffer on the rollers.
I'm going to try messing with the fuel a bit and get my free re-try and if I fail then I'll just register at my ex-gfs place that doesn't need emissions so I can figure this out later. (I was pulled over the other day because my registration expired in july. Whoops...) |
Posted: Thu Aug 25, 2005 12:28 am Post subject: |
The ARCO I've ran made some serious carbon deposits and would cause all my rigs but one to diesel. Switch stations and it went away. Milage went up to.
The Union 76 around here all say Conoco/Phillips 66, is that owned by BP? I know BP owned Arco and AMPM, but they seem to be rather independent of one another...
I had better results that 2.8 from slinky on 76gas.
Ian, you'll want to take out some idle timing, get the engine as hot as you can safely, and pull some fuel out. Do they check for the nox emission where you are? And do they check idle/cruise emissions or do they speed up to 25 and coast a few times? |
Posted: Thu Aug 25, 2005 12:44 am Post subject: |
I think the temp of the engine was somewhat low so that may have affected it. (With the current t-stat and fan turn on temps it never leaves 180*--this I forgot about until I left.) The cat is less than a year old so I don't WANT to replace it but I do know that it could be bad, or just not up to snuff.
It had a full tank of Chevron 89 in it and still has 3/4 of a tank... I'll pick up a can of that Guranteed2Pass crap for friday.
The test was surprisingly fast. I pulled forward on the rollers, she shoved the sniffer in the exhaust, told me to put it in second gear and get between 24-26. Then she told me to let off and pull it out of gear. Then it was over. Dun dun duuuuun. Oh wait... Took me longer to find the damn place than to fail the test...
I'll overlook my current bin and see what I can mess with. I won't get to retest until friday so that'll give me some time.
Thanks a lot guys! |
ET phone hoME Member
Posted: Thu Aug 25, 2005 4:49 pm Post subject: |
wow, im glad i dont have to test for emissions and i kinda wonder what my results would be.... sucks your having all those troubles. _________________ 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops. |
CheezX Member
Posted: Thu Aug 25, 2005 5:30 pm Post subject: |
Set the following in the chip:
Idle O2 Rich/Lean Slow Zero Upper Error = 0.46V
Idle O2 Rich/Lean Slow Zero Lower Error = 0.44V
Idle O2 Rich/Lean Threshold Fast = 0.45V
Your idle may be a bit rougher, it can be tuned out with the idle PID constants. If you need to, bump up the idle speed until it smooths out. As long as it idles steadily under 50kPa it should be fine. Also check the plugs, plug wires, dist cap and rotor. |
Posted: Thu Aug 25, 2005 8:08 pm Post subject: |
Sorry for stealin the thread a bit, but yes Paul 76 is BP. All the BP stations here changed to 76 a few years ago. And on the 76 pumps in longview theres a sticker saying it is a BP company, just like the sticker on the Arco pumps. |
Posted: Fri Aug 26, 2005 12:45 pm Post subject: |
Cheez...
What will that do? Are you reccommending that for an all the time thing or just to pass emissions? Thanks again guys.
Oh yeah, you done fartin around with that xmember yet? Just messin. |
CheezX Member
Posted: Mon Aug 29, 2005 5:50 pm Post subject: |
Those are the target values for the O2 sensor, it will lean out your idle. I drive it like that all the time. You might find that those settings make the idle unstable (which can be fixed with other settings), but it's a good starting point.
My crossmember is done. I found a place to do waterjet cutting, I've got some other projects I'm getting done there. If it works out I can get more crossmembers done there too. I have no excuse for not sending pictures though, except my dad took the camera to Texas! I should try with my cell phone at least. |
