Posted: Thu Jul 25, 2013 9:32 am Post subject: |
chevymad wrote: | Retarded timing makes exhaust heat. Ask Mike about what plug wires do when you forget to plug in the timing connector |
Or when your distributor gear stops being connected to the distributor shaft? _________________
Posted: Thu Jul 25, 2013 9:40 am Post subject: |
If you remote noid most gear reduction starters they have a run on issue. The motor creates a coil field which keeps the solenoid open.
Must have good clean starter and battery leads.
Yes time to adjust your tune. :0) _________________ A redline a day keeps the carbon away! |
Posted: Fri Jul 26, 2013 10:42 pm Post subject: |
I have crappy Flowtech headers and a Jegs gear reduction mini starter. I haven't had a heat soak problem yet. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sat Aug 24, 2013 10:24 am Post subject: |
Fun question..
I years ago, in an act of brilliance, removed the mounting bracket that holds all the relays by the drivers side firewall so I could mount my Jacob's Ultracoil there. The downside is that now I have no method of ID'ing the relays easily.
Every photo or reference I have found says that The fuel pump relay looks like this:
[img]http://i.ebayimg.com/00/s/MjU0WDI5MA==/z/olEAAMXQTghRN6wz/$T2eC16VHJGoE9nuQfepFBRN6wzDhKg~~60_35.JPG[/img]
I am almost sure mine looks like this:
[img]http://i.ebayimg.com/t/IDLE-RELAY-FUEL-PUMP-RELAY-CORVETTE-FIREBIRD-CAMARO-TRANS-AM-1986-1985-1984-1983-/00/s/MTg3WDI0Nw==/$(KGrHqZ,!oQF!K6tt)S5BQPs3k8P8w~~60_35.JPG[/img]
And I think it is intermittently failing. If I bypass it the fuel pump it will run... sometimes. If the car is hot it will almost never prime with the relay.
can anyone confirm what the Relay should look like for a 1988 TPI car? Thanks! _________________ 86' firebird (Junked in 2015). 88' GTA (sold in 2020).
aaron_sK wrote: | Hell, Tony drove his GTA to Cows a few years back with the pickup coil that came out in pieces. |
Posted: Sat Aug 24, 2013 10:32 am Post subject: |
I think in '88 the second one (old style) is the one. '89 was the first year of the new round relays. The old style had issues with the wiring shorting at the plug and the relays failing.
Should be able to ID the fuel pump relay by the wire colors going into it. Should have a dark green/white stripe going into the center pin (PinC)
If it is dead I would replace it with a regular Bosch 5-pin relay. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sat Aug 24, 2013 11:34 am Post subject: |
Why would you replace it with the newer style? Just better?
Also, My timing was off. Retarded by about 8*. |
Posted: Sat Aug 24, 2013 3:12 pm Post subject: |
I wouldn't use the newer style either. I would use a standard Bosch relay like so:
Here's the problem:
1. Old style fails a lot and the wiring pigtail to the plug usually shorts out due to sheath shrinkage.
2. Newer style fails less but is more expensive and hard to find, plus you have to change the pigtail to swap to them.
3. Bosch relays are literally everywhere and dirt cheap. I probably have 5-10 in my toolbox right now. Still have to change the pigtail though.
Here's a shitty TGO picture of the problem I described in number 1. If your relay wiring looks like this it is time to fix them before your car burns down:
Posted: Sat Aug 24, 2013 5:02 pm Post subject: |
mine are not doing the #1 problem.
I have about 7 of those relays brand new, with new solder-on pigtails that match them, i'll use those. |
