upper intake plenum-90-92 tpi
MrMike98
PostPosted: Thu Jul 04, 2013 5:51 pm    Post subject: upper intake plenum-90-92 tpi Reply with quote
need late model plenum. want to do some porting practice....
thanks
Mike
PostPosted: Wed Jul 10, 2013 2:53 pm    Post subject: Reply with quote
I have a good looking plenum i could part with, how can I tell what year range it is from?
PostPosted: Wed Jul 10, 2013 5:31 pm    Post subject: Reply with quote
Assuming we're talking about the upper plenum here: there are several ways, but the quickest is to look for the triangular hole in between and below the front throttle ports. The later cars did not have one.
*Edit: These pictures are poor, but you get the idea:
http://www.hotrodlane.cc/Streetstories/choosingtpi2.htm
PostPosted: Wed Jul 10, 2013 10:02 pm    Post subject: Reply with quote
its the later kind. I think i pulled it of an 89. interested?
PostPosted: Thu Jul 11, 2013 10:04 am    Post subject: Reply with quote
Also, the '89 is considered later style due to the throttle body changes starting in '89 but won't have the MAP sensor port which 90-92 do.
