redlava Member
Posted: Tue Jun 04, 2013 7:14 pm Post subject: Cruise control help |
My cruise control is broken. i have tested the activation lever and it works. I believe there is a problem with the control module. However i missing the part of my haynes manual for testing the cruise control. Are there any tests for checking the control module? I also have not replaced the vacuum lines, based on searches others have replaced the lines and it did not solve their problem. |
