91camaro_rs Member
Posted: Wed May 29, 2013 8:24 pm Post subject: mysterious rubbing noise |
so its only when take right turn and at a certain speed like 25ish my driver side wheel makes a bad rubbing noise, and i jacked up my car and moved the wheels back and forth to see if anything was rubbing and there wasnt any thing, anyone have ideas of what could be doing this _________________
Posted: Wed May 29, 2013 8:42 pm Post subject: |
Jacking it up puts the wheels in a different place.
I wonder if it's rubbing on the inner fender insert? _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Wed May 29, 2013 9:07 pm Post subject: |
the inner fender well liner thing is removed on that side _________________
Posted: Thu May 30, 2013 5:16 am Post subject: |
Twilightoptics wrote: | Jacking it up puts the wheels in a different place. |
Even if you jack under the a-arm you have still changed the mechanical advantage on the spring. You are also not accounting for body roll when you do that. When you take a right turn the driver's front is running lower than the other three corners.
Is it metal on metal, rubber on metal or rubber on plastic? Is it intermittent (once per revolution) or constant?
What wheel and tire combo are you running? What suspension? Do you have a steering box with the proper stops for wider tires or are you still running the factory RS box?
Take the wheel off and look for scuff marks on the wheel, tire and car. Also you might take a glance at the brakes for any abnormal wear. |
91camaro_rs Member
Posted: Thu May 30, 2013 5:28 pm Post subject: |
i just put on all new pads and rotors front and rear last month, there is rubbing marks but thats from turning at full stop full turn, when i take a right turn and it makes the noise im only turning like halfway. i have 17x8 iroc wheels on 245-45-17 nitto NT555's. stock RS steering box. it just starting making this noise pretty recently too. and its a constant rubbing sound now that i thing about it it might be a really bad vibration compared to a rubbing sound. it lasts like 2 seconds...well then the turn is over and it doesnt do it every time _________________
Posted: Thu May 30, 2013 10:42 pm Post subject: |
Wheel bearing was too tight or too loose when you put the rotor on. _________________ A redline a day keeps the carbon away! |
Posted: Fri May 31, 2013 6:01 am Post subject: |
Sounds like a wheel bearing to me. _________________ 84 Camaro Z28 - LS1/T56
91camaro_rs Member
Posted: Sat Jun 01, 2013 12:26 pm Post subject: |
that would make sense, those bearings are probably shot now, ill swap em out, whats the tightening spec on those? _________________
MrMike98 Member
Posted: Sat Jun 01, 2013 1:35 pm Post subject: |
raise car
tight spindle nut to 12lbft while spinning the tire forward
back off the nut to just loose
now hand tighten the spendile nut
now if cottor pin holes do not line up-loosen nut untill it does.
there should be .001-.005" end play when properly adjusted
from factory service manual.
Mike |
Posted: Sun Jun 02, 2013 3:34 pm Post subject: |
Yeah. Ive neve put any wheel bea ring together without even the slightest preload. _________________ A redline a day keeps the carbon away! |
Posted: Sun Jun 02, 2013 5:46 pm Post subject: |
The "backyard mechanic" way is to crank the nut down to 12lb-ft while spinning the hub to seat the bearing, then loosen it until there is noticeable end play, then spin the hub and slowly tighten the nut until you begin to feel a slight bit of drag on the hub. At that point, loosen until a cotter pin hole lines up and you are done.
Very similar to the factory method, if you do it right you will be in spec. It's worth inspecting, repacking and setting up your current bearings again before you go spending more money. _________________ 84 Camaro Z28 - LS1/T56
91camaro_rs Member
Posted: Mon Jun 03, 2013 8:53 pm Post subject: |
just had a shop inspect my car today, they said front and rear wheel bearings are bad/not adjusted right and apparantly your supposed to crush the tabs on the front brake pads to hold them in correctly?? _________________
