jchaussee Member
Posted: Wed May 08, 2013 6:38 pm Post subject: I am finally doing it |
So after a year and a half talking about it, I am doing it. Head swap. Have hood off. Going tostart disconecting things and pull motor. I am pulling motkr because I also want to do a cam swap and clean up and paint engine bay. But before I get crazy what tyles and tips and tricks does everybidy have so I dont have problems when putting it all back in. |
fiveoformula Member
Posted: Wed May 08, 2013 6:57 pm Post subject: |
Take your time, do it as clean as you want it the first time. Don't talk yourself into short cuts thinking "I can always fix that later" because you won't. Lol just ask these guys when you have questions! _________________
'88 FORMULA |
jchaussee Member
Posted: Wed May 08, 2013 7:32 pm Post subject: |
Ya. I am def going to take time. anything in particular I sbould take off to make easier and anutbing in particular I need to make sure goea back same way it went in |
Posted: Wed May 08, 2013 8:18 pm Post subject: |
This topic has already gone on longer than it takes to pull the engine from a thirdgen.
Less talk, more rock.
When you paint the engine bay, don't do the stupid thing that everyone does and paint it black. Paint it gloss white instead. Far easier to see and work in. |
jchaussee Member
Posted: Wed May 08, 2013 8:36 pm Post subject: |
Yes. I saw a bearded man do that once. And ibthought thatvwas clever. |
Posted: Wed May 08, 2013 8:49 pm Post subject: |
I would make sure to label things and take pictures. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
jchaussee Member
Posted: Wed May 08, 2013 8:52 pm Post subject: |
I have been lablin. Pics I didnt do because phone didnt have enough juice and nkt enough flash. I do apologisd in advance for questions that may seem dumb or obvious, but I have never done this. And not as knowledgable or good as you guys. quesyions like this. Should I leave carb and manifold attached? Do I need to mark where distributer is. I am assuming it will not be same when I put back in. and the great question on tgo. Should I pull with or with out tranny. |
Posted: Wed May 08, 2013 9:19 pm Post subject: |
jchaussee wrote: | Yes. I saw a bearded man do that once. And ibthought thatvwas clever. |
Bearded dudes are crazy. _________________
Posted: Wed May 08, 2013 9:30 pm Post subject: |
I always pull them with the transmission attached personally. Never had a problem doing that with a good hoist and load leveler.
I pull with the intake manifold still on usually, use the accessory bolt holes in the heads to lift by. _________________ 84 Camaro Z28 - LS1/T56
jchaussee Member
Posted: Wed May 08, 2013 9:31 pm Post subject: |
K. So should I remove accesorries? |
Posted: Wed May 08, 2013 9:57 pm Post subject: |
I would. I usually leave the waterpump and crank pulley on though. _________________ 84 Camaro Z28 - LS1/T56
jchaussee Member
Posted: Wed May 08, 2013 10:14 pm Post subject: |
Cool. And distributer. Do I need to mark of or anything. |
Posted: Thu May 09, 2013 5:46 am Post subject: |
iansane wrote: | Bearded dudes are crazy. |
Factual!
If you are swapping cams you will retime the distributor anyway.
If the goal of the engine pull is to paint the engine bay then you will want to pull the transmission.
May have already been mentioned, but pull the radiator and fans first. Also, make sure your hoist is long enough to get over the engine. You may have to pull the bumper cover or come in from the side.
Some random engine pull pics to follow:
John and I pull the LG4/700R4 out of Bondo Bucket. Proof positive that you only need a tire iron, a hammer, PB Blaster and Black Butte to pull and engine.
Al and I pull his blown 305. The throat on this hoist was too short. I forget if we came in from the side or what (we obviously left the bumper on it):
Veesix is way easier, you can do it with the hood on. Not actually pulling in this shot, just replacing the oil pan:
jchaussee Member
Posted: Thu May 09, 2013 6:25 am Post subject: |
I love the white engine bay. I gktta tell ya, those bearded fellas may have slmetbing strange and sinister abkut them, but they sure know thier automobile machines |
Posted: Thu May 09, 2013 6:52 am Post subject: |
White is a bad idea trust the guy who has a white car. It gets nasty fast! _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Thu May 09, 2013 7:35 am Post subject: |
I,do agree,on the whole white car thing, I hate white cars. But thr brigjt engine bay is appealing. I need to figure out color combi for block and heads now |
jchaussee Member
Posted: Thu May 09, 2013 7:38 am Post subject: |
Also.,the,same guy who gsve me rear Also gave me a delta cam.. Anybody with expiririence or knowledge about them? |
Posted: Thu May 09, 2013 8:08 am Post subject: |
Twilightoptics wrote: | White is a bad idea trust the guy who has a white car. It gets nasty fast! |
True that. Aaron's engine bay idea is a good idea to spot leaks and have lots of contrast while working on things, but the very nature of that means it will always be dirty. So do you value a cleaner looking engine bay or improved accessibility? I think we know which side of that line Aaron falls on.
http://deltacam.com/
They grind cams. They're a local small business. They do a lot of work for Subaru guys. _________________ 84 Camaro Z28 - LS1/T56
Posted: Thu May 09, 2013 4:05 pm Post subject: |
Here's a novel idea: How about painting the engine bay the same color as the rest of the car? Or is that against the third gen owner code of conduct or something? |
Posted: Thu May 09, 2013 4:25 pm Post subject: |
QwkTrip wrote: | Here's a novel idea: How about painting the engine bay the same color as the rest of the car? Or is that against the third gen owner code of conduct or something? |
Check: Black on black.
If I had any other color that's what I would do as well. I appreciate a nice form over function aesthetic any day. _________________ 84 Camaro Z28 - LS1/T56
