Volvo stuff again
PostPosted: Sun Mar 24, 2013 10:05 pm    Post subject: Volvo stuff again Reply with quote
So last time my Volvo 2.0L turbo was having misfire problems, I changed the spark plugs with some Denso Platinums and the problem went away and the car drove great - for about a week. It has been running like crap for a while now and today I changed the plugs again. This time I went with cheapo Autolite Iridiums. Again the car runs and drives like new, but for how long? I really don't wanna be changing the plugs every week. Two of the plugs I pulled looked fouled and the other two looked good. What would cause the plugs to foul so quickly?
PostPosted: Mon Mar 25, 2013 7:15 am    Post subject: Reply with quote
Are they fouled from oil? like wet or dry fouled?
'88 FORMULA
PostPosted: Mon Mar 25, 2013 8:40 am    Post subject: Reply with quote
Wet, seems like with fuel.
PostPosted: Mon Mar 25, 2013 8:42 am    Post subject: Reply with quote
compression check?
PostPosted: Mon Mar 25, 2013 8:44 am    Post subject: Reply with quote
And leakdown, if you can.
PostPosted: Mon Mar 25, 2013 4:46 pm    Post subject: Reply with quote
How is the plug gap?
Are you sure you're putting turbo specific plugs in?
Anything can cause plugs to foul. Too strong a spark, weak spark, oil contamination, excess fuel, too cold a plug heat range, etc.
How many miles on this pig?
Fuel filter replaced ever?
I suspect maybe it's time to have the injectors cleaned. Doctor Injector does a great job and they are very reasonably priced.
PostPosted: Mon Mar 25, 2013 4:53 pm    Post subject: Reply with quote
The car is fouling plugs because it is running in limp home mode.
That's what that light means on the dash.
I told you this two years ago when I last worked that car. Razz
PostPosted: Mon Mar 25, 2013 4:56 pm    Post subject: Reply with quote
Seriously? What's the check engine light code? What year is this? Come on NEWB we need more details.
Most ODB2 cars don't actually "LIMP HOME" unless it's a certain type of fault.
PostPosted: Mon Mar 25, 2013 5:03 pm    Post subject: Reply with quote
Hell if I know. Last time I messed with this car was two years ago. Had SES light on, smelled and felt like it was running rich, and John was complaining of fouled plugs and poor economy.
I told him this was a no-brainer and he needed to pull codes and figure it out. Then, because John Stahlman, nothing happened for a very long time and now here we are. Razz
PostPosted: Mon Mar 25, 2013 5:11 pm    Post subject: Reply with quote
Rock on!
That's all John sees.
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
Rock on!
PostPosted: Mon Mar 25, 2013 5:19 pm    Post subject: Reply with quote
The code was for a mis-fire if I remember correctly.
PostPosted: Mon Mar 25, 2013 6:22 pm    Post subject: Reply with quote
Rock on!
Absolutely factual!!! Laughing so hard it hurts
PostPosted: Mon Mar 25, 2013 8:16 pm    Post subject: Reply with quote
Rock on!
I wish I could deny it. Very Happy
The SES was for an emissions sensor that i was never able to find. I reset that code long ago and it never came back. The only other codes were for misfires. I am gonna have to bite the bullet buy the expensive Volvo plugs. Sad
PostPosted: Thu Mar 28, 2013 1:54 pm    Post subject: Reply with quote
Moot point now. The Volvo is DEAD. Crying or Very sad
PostPosted: Thu Mar 28, 2013 2:34 pm    Post subject: Reply with quote
What kind of dead?
PostPosted: Thu Mar 28, 2013 8:48 pm    Post subject: Reply with quote
Que muerta?
PostPosted: Thu Mar 28, 2013 9:14 pm    Post subject: Reply with quote
From his text, the oil light came on, he pulled over, checked the oil and it was full, so he continued on his way and the car started smoking and died. This happened in the middle of the 520 bridge.
Maybe the oil pump went bad?
PostPosted: Thu Mar 28, 2013 11:04 pm    Post subject: Reply with quote
Nothing like breaking down in the middle of the 520 bridge during rush hour! Very Happy
PostPosted: Fri Mar 29, 2013 9:10 am    Post subject: Reply with quote
520 sucks
Guess you found the source of fouling.
PostPosted: Thu Apr 04, 2013 4:44 pm    Post subject: Reply with quote
Sucks, but we all know the Swedish/Danish girls when mistreated by their fathers become self destructive.
Laughing
Shocked actually no, that's not funny.... Embarassed
