Posted: Sat Jun 23, 2012 7:13 pm Post subject: |
DBL_TKE wrote: | Now that I have this new CF grill and these smoked turn signals, my fog lights look a little out of place being old and dated looking. So I found some Pilot fog lights that I like. I believe that they are the same ones that Paul had on his IROC. I always liked the sleeker look that his had. I'm in the process of installing them right now actually.
They should look just fine. I have a pair of dual duty Hella fog/driving lights that are about the same size on my 92. I did mount them using a pair of modified 4th gen brackets, though. _________________ 92 Camaro
Posted: Sat Jun 23, 2012 7:19 pm Post subject: |
So what you're saying is, when you take off foglights it rains? Put yer damn foglights back on! _________________
Posted: Sat Jun 23, 2012 8:24 pm Post subject: |
I'm mounting them using the stock holes for now, which is going to keep them a little more reccessed compared to stock. It actually kind of irritated me how far forward the stock fog lights sat. If they sit to far back then I'll drill some new mounting holes further forward.
@Paul: how did you mount yours? They look like they almost sit in the same position as stock, the brackets that came with these don't look like that would be possible. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sun Jun 24, 2012 10:48 pm Post subject: |
Posted: Tue Jun 26, 2012 7:38 pm Post subject: |
I received my strut mounts today.
And my LCARB's arrived too.
Posted: Tue Jun 26, 2012 7:52 pm Post subject: |
You are going to town on that girl
-Schultzy |
Posted: Tue Jun 26, 2012 7:54 pm Post subject: |
The strut mounts will be a real nice upgrade. The stock rubber units deflect an incredible amount. |
Posted: Wed Jun 27, 2012 10:43 am Post subject: |
Schultzy89GTA wrote: | You are going to town on that girl
-Schultzy |
And on his car too! _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Wed Jun 27, 2012 11:55 am Post subject: |
Posted: Wed Jun 27, 2012 12:20 pm Post subject: |
I really like the Founder's mounts. They seem well made and really helped tighten up the front of the car. It's amazing how much deflection the stock rubber strut isolators have. _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed Jun 27, 2012 6:50 pm Post subject: |
Founders mounts + del alums = sooooo awesome. _________________
Posted: Sat Jan 26, 2013 2:23 pm Post subject: |
Wow, I guess I never updated this since my accident. Well the body and frame damage still hasn't been fixed yet. It will, when I can afford it. But I did install the Founders raised strut mounts and LCARB's, and I also installed some 1" extended ball joints. The extended ball joints took away enough strut travel to the point where they could bottom out, not good. So I raised the car back up about 1.5" until I can get some drop spindles. I plastidipped my SS wheels so I'm running those now.
charlie6178 Member
Posted: Tue Jan 29, 2013 10:26 am Post subject: |
i have a guy with a frame bench that can straighten the frame rails after hours for cheap if you want to get it back straight. _________________ 1992 Camaro 1LE Z28 |
Posted: Fri Feb 01, 2013 3:31 pm Post subject: |
Sure do. I just got my GTI put back together so it'll be road worthy again. Then I can focus on fixing the Camaro. |
Posted: Sat Mar 30, 2013 3:21 pm Post subject: |
Well the GTI is the daily driver again now. Charlie, lets talk more about getting the frame straightened. |
charlie6178 Member
Posted: Mon Apr 01, 2013 4:46 pm Post subject: |
shoot me a text and we can take it next door and talk with the guys 503-866-1711 _________________ 1992 Camaro 1LE Z28 |
Posted: Tue Jul 16, 2013 4:17 am Post subject: |
Finally something new for this car
Posted: Thu Oct 17, 2013 1:33 am Post subject: |
Looks like I haven't posted any pictures or updates lately. I've been autocrossing competitively this year with the Oregon Region SCCA. Last weekend marked the last two events of the season and I ended up 2nd overall in points for the season in my class, STU. Here's a few shots during some races in Packwood, WA. props to Al for most of these awesome photos.
Posted: Thu Oct 17, 2013 8:38 pm Post subject: |
And now that the racing season is over, I am about to embark of some more drastic work. First off I decided to get the car back to a more desired ride height. I'm not going to be racing during the winter so it doesn't need to be a 4x4 anymore. Pretty sure I'm not going to be going any lower anymore .
The car is going to a friends shop soon to get the frame straightened then I will be fitting up these wheels.
18x10.5 +20 XXR 526's with Chromium Black centers and chrome lips front and rear. I'll have to play the spacer game to get the fitment just right. Tire choice is still up in the air. I'm leaning towards either the Dunlop Direzza Z2's or BFG Rivals. Size will most likely be 275/35/18. Though I say tire choice is up in the air because I will no longer be running in STU next year but instead I should be in Street Mod (SM). "Why the change?" you ask? well...
