AKMark New Member
Posted: Sun Jul 31, 2005 2:44 pm Post subject: 89 firebird backup lights |
Lights are inop, all fuses test OK, but no power to the bulb.
This is a 2.8 with 5sp and I am unable to locate any information on the location of the backup light switch.
Any info appreciated.
Thanks! _________________ 86 Camaro, L34, 700R4, 2.73 and T-top. So far it's all original.
89 Firebird 2.8, 5 speed t-top, won't start! |
Posted: Sun Jul 31, 2005 3:09 pm Post subject: |
What year 2.8/5spd?
if it is a year with a speedo cable, it will be the only wire coming out of the tranny, if it is a electric speedo, it will be the one that is not the speedo. |
turbo_jimi Member
Posted: Sun Jul 31, 2005 9:50 pm Post subject: |
Sig says 86....and i don't think it would have anything to do directly with the tranny
could be wiring from the reverse all the way to the lights...did you check continuity in the light sockets? Have someone put it in reverse (with the clutch depressed of course...lol) and check that. then trace the wiring on back. Good luck!
TJ _________________
Midnight Sun Member
Posted: Tue Aug 02, 2005 5:45 pm Post subject: |
You check the reverser fluid? _________________
turbo_jimi Member
Posted: Tue Aug 02, 2005 5:47 pm Post subject: |
LOL...I have the reverser fluid as an 85 option...did they have it in 86? Just joking... _________________
BigDaddyVu 12sec Club
Posted: Tue Aug 02, 2005 8:57 pm Post subject: |
thats an ez fix i had that problem with my 86 fireturd its the conntacts from the hatch lid to the truck (next to the truck latch) just sand it and it will work don't forget to put lithium grease on them. |
