Posted: Wed Feb 13, 2013 10:13 am Post subject: Dodge Cummins Injectors? |
So I'm looking to trade my car for a 3/4 ton truck. I have found an 04 dodge with the "c" code cummins engine. I am told it has leaky injectors, which from google searching appears this is a normal issue? Also looks like its not toooo overly difficult.
Pull rail
pull feader tubes
pull "valve cover"
pull one of the rockers
pull injector
Only thing I havent searched deep on, is re-installing the rocker. If its a torque to setting, or a "by feel" adjustment.
Can anyone confirm the normal issue, and amount of work? _________________ 2008 GMC Z71
Posted: Wed Feb 13, 2013 9:49 pm Post subject: |
Didn't you just recently talk yourself in to selling a 1 ton truck and say a Blazer can tow really well?
Posted: Wed Feb 13, 2013 9:58 pm Post subject: |
QwkTrip wrote: | Didn't you just recently talk yourself in to selling a 1 ton truck and say a Blazer can tow really well? |
Stop it with the logic!
Dang.. I got a set of stock cummins lifters at work, but forgot to check which year they're for. I think they're for a 98 though. Someone upgraded and gave me the "old" ones. |
Posted: Wed Feb 13, 2013 10:07 pm Post subject: |
So what are you going to tell your wife?
Happy Valentine day, honey! I sold our nice car for an old tired truck! |
Posted: Wed Feb 13, 2013 10:11 pm Post subject: |
I dunno guys, if I had a choice between the combo of a 6.5 GMC and a highfalutin Nissan versus a Common Rail I know which way I'd go.
As long as the tranny doesn't crap the bed, the injectors don't peter out, the lift pump doesn't die and the front ball joints don't walk away he'll be fine.
Seems to me like the CTD lash is set with a setscrew on the rocker, not by the hold-down bolt. |
Posted: Wed Feb 13, 2013 10:34 pm Post subject: |
But then again, you're not married either....
If you had an Infinity in the driveway, then I can guarantee you'd have your choice of middle aged women to pick from. |
Posted: Thu Feb 14, 2013 3:46 am Post subject: |
So it appears nobody has done this on here? |
Posted: Thu Feb 14, 2013 7:50 am Post subject: |
Give me the engine serial number _________________ A redline a day keeps the carbon away! |
Posted: Thu Feb 14, 2013 10:39 am Post subject: |
That I dont have, havent went and looked at the truck yet. All I know is 04 "c" code engine. |
Posted: Thu Feb 14, 2013 7:06 pm Post subject: |
I don't even know what a "c" code means. In Cummin's land we go by the ESN. Typically Cummin's injectors are simple, and the lash SHOULD be set by a feeler gauge, not torqueing the rocker rail.
So is it a 5.9 or? _________________ A redline a day keeps the carbon away! |
Posted: Thu Feb 14, 2013 9:59 pm Post subject: |
Twilightoptics wrote: | I don't even know what a "c" code means. |
Dodge engine VIN code.
Diesel jocks are sketchy as f*wk for having any sort of useful info but it looks like Dodge did some half-year business in '04 rolling out the 600tq engines.
I still say quit worrying and buy it. CTD guys swap injectors out all day long trying to break their transmissions. It can't be that hard if they've got it figured out.
I only see one problem with this whole scam (and one of you grizzled married guys may confirm or deny my theory). With the highfalutin Nissan and the GMC out of the way the Dodge will be by far the nicest vehicle you own. In practice women never drive Camaros (what with the breaking down and all) and she won't want to drive your Blazer around with the gas can hanging on the bumper, so she'll be down to driving your truck, and trust me, some of those new CTD's are pretty damn woman-ized with the smooth and quiet ride. |
Posted: Fri Feb 15, 2013 3:48 am Post subject: |
Twilight, I did look up the rocker arm setting, and yes it is set with feeler gauge. Didnt know that tell I looked it up.
Aaron, I dont give a damn what any woman thinks, or cares about me. Let alone, plans on driving my stuff since my insurance policy clearly states "NO FEMALE DRIVERS". Yes, it says that. |
charlie6178 Member
Posted: Fri Feb 15, 2013 1:27 pm Post subject: |
have you looked at prices at all on the common rail injectors???? _________________ 1992 Camaro 1LE Z28 |
Posted: Fri Feb 15, 2013 3:40 pm Post subject: |
91RSVert wrote: | Aaron, I dont give a damn what any woman thinks, or cares about me. Let alone, plans on driving my stuff since my insurance policy clearly states "NO FEMALE DRIVERS". Yes, it says that. |
Well, I guess that settles that. |
Posted: Fri Feb 15, 2013 6:44 pm Post subject: |
charlie6178 wrote: | have you looked at prices at all on the common rail injectors???? |
250 for remans
350 for new
I am heading out in the morning to go look at it. 2.5hr drive each way. |
charlie6178 Member
Posted: Sat Feb 16, 2013 5:35 pm Post subject: |
you know that is priced per injector right???? thats $350 a piece! _________________ 1992 Camaro 1LE Z28 |
Posted: Sat Feb 16, 2013 5:52 pm Post subject: |
I had a ford in the other day. 36k miles bad injectors and they burned out the injector driver as well. Almost $900 apiece for injectors $500 for the driver and it needed to be flashed. Sent that thing back to Ford. |
Posted: Sat Feb 16, 2013 7:22 pm Post subject: |
charlie6178 wrote: | you know that is priced per injector right???? thats $350 a piece! |
Yes I knew this |
