fiveoformula Member
Posted: Thu Dec 13, 2012 7:08 pm Post subject: Third Gen V8 T5 swap |
Wanted to see if there's any interest out there, I have everything for a T5 swap still working in my car right now, considering going a different route with a transmission.
I have the following;
-Non-World class T5, unknown mileage but very strong, no grinds while shifting, always ran syncromesh fluid.
-New master and slave cyls (fluid lines and resivour also included).
-V8 bell housing
-Used clutch with approx. 20k on it.
-Hurst billet-plus Shifter (like new).
-Clutch and Brake pedal set (can be reused but I recommend a different set).
-also have a firebird 5 speed shift plate in pretty decent shape
I was thinking $500 for everything, maybe $400 without the shifter. May be negotiable. If anyone is interested I can take you for a ride in the car so you can see how well it shifts. Shoot me a PM if you would like _________________
'88 FORMULA
Posted: Thu Dec 13, 2012 7:19 pm Post subject: |
Don't tell me your knees are worn out already. |
fiveoformula Member
Posted: Thu Dec 13, 2012 7:43 pm Post subject: |
Dang it Aaron, "going in a different direction" not good enough?? Lol |
Posted: Thu Dec 13, 2012 8:36 pm Post subject: |
I've seen you fishing 700's on TGO.
Terrible idea for a commuter IMHO. Need a stick in traffic. Leave the auto for drag cars and towing. |
Posted: Thu Dec 13, 2012 8:47 pm Post subject: |
Just a forewarning. I will not be helping you with this swap if it happens. I do not condone this behavior. |
Posted: Thu Dec 13, 2012 8:56 pm Post subject: |
Ehh bring it up here, I'll help with the swap. I'm an amoral asshole anyway. |
Posted: Thu Dec 13, 2012 9:00 pm Post subject: |
A stick for traffic? Masochist.. |
Posted: Thu Dec 13, 2012 9:04 pm Post subject: |
The Bimmer has spoiled me. Dual mass flywheel, deep first gear and a fairly light clutch.
A T5 is a decent traffic transmission. T56 less so. |
Posted: Thu Dec 13, 2012 9:05 pm Post subject: |
Yeah wtf. Auto IS for traffic and drag racing. _________________ A redline a day keeps the carbon away! |
fiveoformula Member
Posted: Thu Dec 13, 2012 9:12 pm Post subject: |
For most of my driving the T5 is kind of a pain. A few years ago I just had to shift my own gears. Now I'm up in the air. For the stop and go BS driving. Auto is way better. _________________
'88 FORMULA |
Posted: Thu Dec 13, 2012 9:15 pm Post subject: |
Speaking of dual mass flywheels.. had a ford one in today.. bearing went bad.. The whole clutch flywheel surface, disc and pressure plate were offset 1/4"... can you say vibration?? Poor powerstroke.. |
Posted: Thu Dec 13, 2012 9:27 pm Post subject: |
Jeez. Did you replace it or just bolt it up?
I seem to recall the spec being to replace the entire flywheel assembly every time you did the clutch. I'm sure Ford didn't mind charging an extra $1000 every clutch job. |
Posted: Thu Dec 13, 2012 9:38 pm Post subject: |
Clutch/flywheel is a year old.. Installing the non dual mass replacement kit. Vibration was so bad it almost made that crewcab hop. |
Posted: Thu Dec 13, 2012 9:47 pm Post subject: |
chevymad wrote: | flywheel is a year old. |
Defective unit or do you think the guy did something to bork it up?
I believe you on the vibration. It will be rattly enough with the single-mass unit in there. |
Posted: Thu Dec 13, 2012 9:49 pm Post subject: |
All dual mass flywheels die at some point. They are like buying a spectre brand harmonic balancer. Imagine the vibration with the same offset failure on a 150lb version on a 16 liter. Almost got the semi tires off the ground.
If you have a love of driving keep the stick. You will wish you had it back when you wanna have fun. And when the 700 takes a crap. And it will. You'll kick yourself. _________________ A redline a day keeps the carbon away! |
fiveoformula Member
Posted: Thu Dec 13, 2012 10:06 pm Post subject: |
I am under no delousions that 700's or any automatic is bullet proof. I've blown one myself. I am getting fairly tired of bleeding my clutch and it still not getting good disengaugement, cruising around and stop and go I might enjoy the car more with a "relaxed" driving style. The place I love the 5 speed the most is out on the backroads. But only time I do that is for fun |
Posted: Fri Dec 14, 2012 10:03 pm Post subject: |
your...ford is for everyday driving in traffic. The bird is for fun days. How often do you drive it these days anyway? |
Posted: Fri Dec 14, 2012 10:31 pm Post subject: |
fiveoformula wrote: | I am getting fairly tired of bleeding my clutch and it still not getting good disengaugement, |
What clutch? What TOB? How many miles on it? When you bleed it are you using vacuum or just pressure/gravity? |
Posted: Sat Dec 22, 2012 10:15 am Post subject: |
If you're going to take a step backwards, I got a whole mechanical linkage setup sitting collecting dust if you're sick of the hydro stuff :poke:
Quote: | What clutch? What TOB? How many miles on it? When you bleed it are you using vacuum or just pressure/gravity? |
^ that. You'd be amazed at how most of the reman and a lot of the aftermarket brands have taken a dump in the last few years. |
fiveoformula Member
Posted: Sat Dec 22, 2012 11:45 am Post subject: |
Everything in the bell housing is about 3 years old, roughly 20k on it all. I've tried all kinds of ways to bleed the system, when I checked last, the slave rod moves 1" with pedal depressed. But it feels like the disengaugement got worse since then.
And skyler id like to drive my fun car MOST of the time, not one or two days a week. _________________
'88 FORMULA |
