My 82 T/A
Goto page Previous  1, 2, 3
RK82
1982 Pontiac Trans Am
PostPosted: Tue Nov 20, 2012 1:40 pm    Post subject: Reply with quote
I haven't updated this in while..not much changed, I drove it all summer made it to 5 street legal nights best time was a 15.33 at 88mph.
I added a H-pipe to the exhaust
after the exhaust the car was running alittle lean, when I went to change the jets my elcheapo chrome fuel line twisted off
I may have got carried away with AN fittings and braided line again but I like this setup alot better, I don't even have to take the fuel lines off to change jets. I didn't have a 90* degree fitting so the line for the rear bowl is alittle long.
RK82
PostPosted: Tue Nov 20, 2012 2:05 pm    Post subject: Reply with quote
Middle of july I took the car on a 1200KM roadtrip to see my parents, I took few pictures along the way.
overheated on the side of the road, really need an airdam
RK82
PostPosted: Tue Nov 20, 2012 2:59 pm    Post subject: Reply with quote
In front my girlfriends parents house
this seemed like good spot for some pictures, the gravel pit in the back ground of the first picture is where we used to party back in highschool.
RK82
PostPosted: Tue Nov 20, 2012 4:50 pm    Post subject: Reply with quote
a few pictures of the car going away for the winter
since its that time of year again I've been collecting parts,
black door panels, almost done converting my interior to black, debating on leaving the headliner and seats grey.
this is completely over kill for my engine but it was shiny and...I'll just leave it at that..lol
fully adjustable mechanical/vacuum advance with a built in rev limiter
comp XE262H cam and all the required parts for it
comp magnum 1.52 roller tip rockers
this should be a fun winter.
RK82
PostPosted: Fri Jun 14, 2013 12:13 pm    Post subject: Reply with quote
haven't updated this for awhile, I finished doing the cam swap.
but it didn't really have any more power than it did before. best pass before was a 15.35 at 88mph after it went 14.93 at 93 mph, shoulda known better the bottom end was done.
I also got sick of dragging the exhaust on every bump or dip in the road went back to a 3" single with a flowmaster 80
this was my first try at building a y-pipe
RK82
PostPosted: Fri Jun 14, 2013 12:24 pm    Post subject: Reply with quote
my buddy had this 88 L98 sitting around, here it is after a good cleaning and paint
and in the car
best pass so far has been a 14.12 at 98 I haven't done any tuning yet the carb and distributor are still set up for the 305
PostPosted: Sun Jun 16, 2013 3:43 pm    Post subject: Reply with quote
Looking good! Keep up the great work! Thumbs up
PostPosted: Sun Jun 16, 2013 6:12 pm    Post subject: Reply with quote
So did you scrap the other engine or put the new cam/springs/rockers in the L98? Cool looking car, just making sure I am following the progress here Very Happy
RK82
PostPosted: Sun Jun 16, 2013 8:51 pm    Post subject: Reply with quote
I put the cam/springs/rockers in the 305 drove it for probably 3 weeks then it started smoking really bad. I tore it down and found 3 broken rings, one piston was different from the other 7, and the two center main bearings were down to copper. The L98 is still stock
PostPosted: Sun Jun 16, 2013 8:58 pm    Post subject: Reply with quote
Every time you re-up this thread I remember how much I like the look of this car. Cool
Any reason the cam didn't make it into the new motor?
PostPosted: Mon Jun 17, 2013 7:14 am    Post subject: Reply with quote
I'm guessing the 305 was flat tappet and the L98 is roller.
PostPosted: Mon Jun 17, 2013 12:02 pm    Post subject: Reply with quote
Got it. Thanks!
Looking good man.
RK82
PostPosted: Mon Jun 17, 2013 6:07 pm    Post subject: Reply with quote
pretty much, I still have that whole cam kit, not sure what to do with it yet, its probably pretty hard to sell a used cam
PostPosted: Mon Jun 17, 2013 6:08 pm    Post subject: Reply with quote
Makes sense.
If you keep the lifters matched someone will buy it.
PostPosted: Mon Jun 17, 2013 6:27 pm    Post subject: Reply with quote
Comp 262xe makes great power. Mine was fun until it went flat.
PostPosted: Mon Jun 17, 2013 7:24 pm    Post subject: Reply with quote
Sold my 262XE cam with the lifters matched for like $75!
Page 3 of 3
