Upper fan mount, belt buckles, hood latch
PostPosted: Sun Oct 21, 2012 6:39 pm    Post subject: Upper fan mount, belt buckles, hood latch Reply with quote
1) The upper radiator/fan mount from a V8 car (but not the one with the big clutch fan shroud!) Don't need anything fancy.
2) Front seat belt buckles from a second-gen or very early thirdgen. These have the buttons on the side like an old-schooler not the top-mount buttons like the later cars. Color is insignificant. I would prefer the plastic brace be intact.
3) A hood latch (the actual latch this time) with the return spring intact and not all sloppy and crappy like mine. Embarassed
As usual a local beer trade is preferred, but I can do the PayPal and ship thing as well. Cool
PostPosted: Mon Oct 22, 2012 6:57 am    Post subject: Reply with quote
RE: Hood latches.
Dorman:
http://www.top-downsolutions.com/Body-Parts/Exterior/hood-latch-assembly
GM OEM:
http://www.hawksthirdgenparts.com/products/Latch%2C-82%252d92-Camaro%7B47%7DFirebird-Hood-Latch%2C-new-GM.html
Why not get one from the good old junkyard?
PostPosted: Mon Oct 22, 2012 7:21 am    Post subject: Reply with quote
Oh I I could buy all this stuff from the yard, but it's raining and I'm busy (lazy) and I figured I'll give my money to the Crew before I give it to the junkyards. Wink
PostPosted: Mon Oct 22, 2012 9:01 am    Post subject: Reply with quote
Understood. Smile
PostPosted: Mon Oct 22, 2012 10:18 am    Post subject: Reply with quote
FYI, I found the latch I was supposed to give you with the other assembly if you want it. Very Happy
PostPosted: Mon Oct 22, 2012 3:46 pm    Post subject: Reply with quote
Hells yeah. Thumbs up
Does it have the return spring in it? Mine is completely gone, thus my using a carb return spring... which doesn't work well at all. LMAO
PostPosted: Mon Oct 22, 2012 9:02 pm    Post subject: Reply with quote
Laughing Yeah, fully functional. I might be heading down Wednesday. Give you a call?
PostPosted: Mon Oct 22, 2012 9:16 pm    Post subject: Reply with quote
Absolutely.
But isn't it getting a little cold for wakeboarding? Surprised
PostPosted: Mon Oct 22, 2012 9:17 pm    Post subject: Reply with quote
That's what drysuits are for. Very Happy
PostPosted: Thu Oct 25, 2012 10:28 am    Post subject: Reply with quote
Didn't end up going down. Scheduling conflicts. Sucks when 2 people quit at work and there are only 4 people to run an entire store. Had to cover some shifts! Is next monday-ish okay?
PostPosted: Thu Oct 25, 2012 12:50 pm    Post subject: Reply with quote
I'm in no rush.
PostPosted: Fri Oct 26, 2012 11:41 am    Post subject: Reply with quote
Been looking a new upper fan mount for the T/A for a while as mine has a giant crack in it, with no luck. Tumwater yard is useless for thirdgens now. Sad
PostPosted: Fri Oct 26, 2012 2:59 pm    Post subject: Reply with quote
GM parts direct doesn't list it but you may see if a dealer can give you a superceded number on the OE one. I just bought a new one a few years ago. 10069174
BluFbdy
PostPosted: Sun Oct 28, 2012 6:32 pm    Post subject: Reply with quote
What radiator are you using? I've got the v6 upper shroud in great shape no cracks sitting in my storage
PostPosted: Sun Oct 28, 2012 8:02 pm    Post subject: Reply with quote
If your V6 shroud is from a 3.1, it should work for him. The 3.1 uses the same radiator and shrouds as the V8 - at least they're the same on both of my cars.
PostPosted: Sun Oct 28, 2012 8:49 pm    Post subject: Reply with quote
That car was an '89 as I recall.
BluFbdy
PostPosted: Sun Oct 28, 2012 9:58 pm    Post subject: Reply with quote
2.8, can't remember off the top of my head right now but I remeember it being backwards from my v8, upper hose was on the passenger I think and the lower on the driver side? Whatever stock for an 89 2.8 is lol
PostPosted: Mon Oct 29, 2012 7:26 am    Post subject: Reply with quote
Yup. Before '90 the veesix used a radiator with flipped outlets that was about 4" narrower. After that they used the standard V8 radiator.
