Posted: Tue Oct 16, 2012 9:08 pm Post subject: FS; Random thirdgen stuff |
Trying to clean out the garage of all the stuff that "would be cool to use someday" that I'll realistically never do anything with. All prices are OBO and willing to trade beers.
OEM LS6 Injectors I believe 28 lb/hr? Pt#12561462 $90 O-rings are only a few years old and in great shape. Openings look clean and I had no drivability issues with these.
Crank pulley and water pump pulley from an '87 serp/v-belt car. $10
Rubber fuel lines from a TPI car including hardline fittings $10
Passenger/Driver seat belts from my '91 'vert. I believe they're the same as hardtop cars as if I recall they were the same as my '87s seatbelts. No buckles. $10
Rear marker lights from my '87 $10
Firebird door surrounds. Two right hand, one left hand. $5ea
Trans Am fender vent. Came from an '85. Right side. $5
Reman'd '749 ECM. Pulled from a sunbird. Includes pigtail. $20
3rdgen 5speed lower shift boot $15
Left hand head light door from my '87. Slightly pinkish from fade. Chris? $5
'87 fusebox door cover. Free
3-wire '85 headlight motor/door/bucket/assembly/bezel $20
2-wire '87 headlight motor/door/bucket/assembly $20
'87 Headlight/Dimmer switch w/ bracket and light. $15
OE remote control driver's side mirror and cable assembly. Never been painted. $30
Factory airbag from my '91. $50
'87 Fuel door and bucket. Still red! $10
Posted: Thu Oct 18, 2012 6:55 am Post subject: |
You've had a lower shift boot this whole time?? I'll take it. It appears to not have any rips or tears, am I right? |
Posted: Thu Oct 18, 2012 9:17 am Post subject: |
DBL_TKE wrote: | You've had a lower shift boot this whole time?? I'll take it. It appears to not have any rips or tears, am I right? |
I've had this since I first did the t56 swap I think? It's just gone from different storage tote, to different storage tote. No tears, but you can see it's starting to get brittle. It's yours! Do you want me to hold it until the next time you're up here/I'm down there or ship it to you? _________________
Posted: Fri Oct 19, 2012 5:44 pm Post subject: |
You can just hold onto it. I've been up to the Tacoma/Seattle area so many time in the last few months it's not even funny. I'll let you know the next time I'll be swinging through. |
Posted: Fri Oct 19, 2012 8:35 pm Post subject: |
So I've noticed! Quite the concert goer. _________________
Posted: Wed Oct 24, 2012 9:34 am Post subject: |
Alright, a thread bump before I toss this stuff this weekend. _________________
nonsensekid20 Member
Posted: Tue Jan 01, 2013 10:10 pm Post subject: |
Do you still have those fuel lines? |
Posted: Tue Jan 01, 2013 10:18 pm Post subject: |
No sorry dude, tossed them. _________________
