91camaro_rs Member
Posted: Sat Sep 08, 2012 5:43 pm Post subject: bog down and boom! |
Ok so today my car started a new problem. It just all the sudden bogged down almost dying then it backfires super loud out the exhaust and goes back to normal. I found cylinder 3 plug wire came loose. Put it back on and it still did it. I swapped the chip. And we'll see how things go . What might cause this _________________
Posted: Sat Sep 08, 2012 7:46 pm Post subject: |
Sounds like a plugged cat that blew out and gave you your power back...
But you say it repeats>? _________________ A redline a day keeps the carbon away! |
BluFbdy Member
Posted: Sun Sep 09, 2012 1:41 pm Post subject: |
Oh yeah its repeating, if he hits WOT then let's off its fine but if he holds a steady light throttle rpms drop and then the car will die and fire back up with a loud backfire Idk what's causing it but it startled the crap out of me when we were driving lol sounds like a shotgun with his exhaust _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Sun Sep 09, 2012 2:59 pm Post subject: |
Sounds like a fueling issue. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Sat Sep 15, 2012 8:45 pm Post subject: |
it ended up being the ICM, since i bought the dizzy as a whole i returned it and exhanged it for a NEW richporter dizzy rather than the a1 cordone reman. then the coil went bad so swapped that out too and now all is well! _________________
