charlie6178 Member
Posted: Wed Aug 22, 2012 11:47 am Post subject: cleaning shop |
i have some parts i don't need, figured i'd throw them up and see if anybody else does
HP tuners setup V2.2.0 $200
ZF6 6 speed compelte $750
fabricated LS valvecovers w/coil mounts $150 - new
LS2 fuel rail covers (drivers side has small crack) $50
C6 vararam snake chamer intake - $150
i also have 2 sets of 5.3 LS 706 casting cylidner heads that are complete rebuilts
3 angle seat cut
reground valves
pressure tested
resurfaced .020"
new valve guides
tip heights set
springs shimmed
viton stem seals
glass beaded clean
looking to get $300 per pair ready to bolt on. _________________ 1992 Camaro 1LE Z28 |
Posted: Wed Aug 22, 2012 4:34 pm Post subject: |
How many licenses used on the HP?
that is the suite that edits, not the scanner correct? |
