Nerds needed...
PostPosted: Wed Aug 01, 2012 6:26 pm    Post subject: Nerds needed... Reply with quote
I need some help figuring out an issue. My mother's house had a phone line based intercom system from the gate. If you didn't have the gate code, you'd hit the 'Call' button and it would trip the phone line in the house and you could talk through the regular phone. It just tapped inline to the trip/ring wires at the demark box right outside the house. However, a number of years ago my mother switched to Comcast and lost the original demark box. Now, there is a comcast box that has a phone line coming out of it to a new demark setup. I tried tapping into that and hitting the call button I get nothing in the house. As soon as I disconnect the comcast line and just have the intercom hooked up it rings. The house is setup for and uses two lines (one for phone and one for fax). The intercom is a LiftMaster TAC1 from Chamberlain. Comcast is almost no help whatsoever. I can't imagine this being the only intercom setup with voip?
PostPosted: Thu Aug 02, 2012 7:23 am    Post subject: Reply with quote
The cable guy here at my office(we do phone and catv). Says that combo will not work. They function differently.
PostPosted: Thu Aug 02, 2012 9:25 am    Post subject: Reply with quote
Damn.
PostPosted: Thu Aug 02, 2012 10:21 am    Post subject: Reply with quote
Thats just one person. Keep asking around, maybe someone knows a butcher way to do it, or some "converter" box that will make it work.
IMO, that sounds like to common of a setup for it not to beable to work.
