BluFbdy Member
Posted: Tue Jul 24, 2012 11:54 am Post subject: camaro ac delete box |
Looking for a legit ac delete box, I modified one from an s10 and its sitting too close to my header for my comfort, its maybe a business cards thickness away from it and its starting to flake the paint _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Jul 24, 2012 1:16 pm Post subject: |
@aaronsk
It's like an episode of horders! _________________ A redline a day keeps the carbon away! |
turbo_jimi Member
Posted: Tue Jul 24, 2012 1:54 pm Post subject: |
Twilightoptics wrote: | @aaronsk
It's like an episode of horders! |
Aaron loves A/C delete boxes! Even more than me. _________________
BluFbdy Member
Posted: Tue Jul 24, 2012 2:29 pm Post subject: |
So I guess I gotta wait for him to chime in on this lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Jul 24, 2012 2:51 pm Post subject: |
Or PM him? _________________
BluFbdy Member
Posted: Tue Jul 24, 2012 4:28 pm Post subject: |
iansane wrote: | Or PM him? |
Too much work? Lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Jul 24, 2012 4:46 pm Post subject: |
I think he's working right now. I bet his spidey sense is tingling. _________________ A redline a day keeps the carbon away! |
BluFbdy Member
Posted: Tue Jul 24, 2012 4:54 pm Post subject: |
Wouldn't doubt it lol his mountain man ears are ringing _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Jul 24, 2012 7:33 pm Post subject: |
Blargh.. what's all this then about deleting your box!?
Yes I have delete boxes with motors. Several to choose from. Junkyard fresh. Also have mounting hardware. I was going to bombcan them all and put them on TGO for a hundred or so apiece but I would love to sell them for less now and save myself the cleanup work. I can help install for some extra bucks/beers. Also, if you want to reuse your A/C motor I can show you what type of cage you will need to do that. |
BluFbdy Member
Posted: Tue Jul 24, 2012 8:49 pm Post subject: |
Well I've got it all wired and set for using my ac relay and motor, it was working good with the modified box but its just too close for my comfort, how much do you want for a box? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Jul 24, 2012 8:53 pm Post subject: |
I will go $70 on box with motor if I don't have to paint and ship it.
You can reuse your motor with the new box but you will need a new squirrel cage. I can show you that when you pick up the box. The cage needed is easily found in any junkyard.
You free tomorrow? I'll be around. |
BluFbdy Member
Posted: Tue Jul 24, 2012 9:06 pm Post subject: |
I'm off on weekends usually, is offer to trade you parts but you've probably got a larger stash than me lol ill get a hold of you when I scrape the cash together, everythings been tight since the shipyard hired me, security found an ollllld debt I've been paying off to keep my job lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Jul 24, 2012 11:27 pm Post subject: |
I was under the impression you can use the ac delete box cage on the a/c motor? _________________ A redline a day keeps the carbon away! |
BluFbdy Member
Posted: Wed Jul 25, 2012 5:02 am Post subject: |
I had an ac delete blower before but I had to replace it because the brushes went out, I believe the cage was anal enough because they didn't have the right one and they couldn't order it apparently so I went off dimensions of the cage and the bolt pattern its a bit bulkier and a pain to get in the s10 bow because its really close to the fender well but it works, from looking at it I think ill have more room with a camaro box _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Wed Jul 25, 2012 9:45 am Post subject: |
Twilightoptics wrote: | I was under the impression you can use the ac delete box cage on the a/c motor? |
You cannot. Their are three types of cages and two lengths of motor studs across GM stuff of that era. The aircon cars got the long stud with the tall cage, the delete cars got the short stud with the short cage. To run the aircon motor in the delete box you need a short cage set up for a long stud.
If only someone would have completed the process while building one of these boxes for Jon, and then posted it to the site!
Basically you take both cages off, measure them, then go to the yard with a tape measure, and a 13mm, 10mm, 8mm and 7mm and start yanking motors till you find one with the right cage. Most midsize early 90's cars had the right one, so it's easy to find. |
Posted: Wed Jul 25, 2012 10:27 am Post subject: |
Unless you shorten the motor armature like I did. :O) _________________ A redline a day keeps the carbon away! |
Posted: Wed Jul 25, 2012 12:06 pm Post subject: |
Well aren't you fancy.
That is a good idea Paul, but I think mine is easier. |
Posted: Wed Jul 25, 2012 3:32 pm Post subject: |
I just spaced the motor assembly away from the delete box 1/4" and used my AC cage. _________________
