		jchaussee Member
				 Posted: Sat Jun 09, 2012 3:14 pm    Post subject: i am full of questions. |
				| Anyways I just picked up an auto meter trans temp gauge and figuwred it could probly be installed where it come I.to the radiator? Also what so I ask for as far as a sending init at auto parts store? Can I just get a t fitting and hook it up to trans line and then sender on top? And finally what size are stock cooler lines? |
				 Posted: Sat Jun 09, 2012 4:06 pm    Post subject:  |
				Put it in the pan.
Autometer sells the sender for it. |
		jchaussee Member
				 Posted: Sat Jun 09, 2012 4:08 pm    Post subject:  |
				| If I put in pan do I need bung welded on? And if I pulling pan is it  worth having drain plug installed? |
   1987  Pontiac  Formula
				 Posted: Sat Jun 09, 2012 4:13 pm    Post subject:  |
				| You only need to drill a hole for the drain plug/sensor. The fitting then goes through from the inside and tightens down on a gasket. |
		jchaussee Member
				 Posted: Sat Jun 09, 2012 4:14 pm    Post subject:  |
				| Sweet. Thanks. |
				 Posted: Sat Jun 09, 2012 5:18 pm    Post subject:  |
				Mine needed a bung welded in. It was a Sport Comp gauge. Yes, put it in the TRANSMISSION OIL PAN. _________________ A redline a day keeps the carbon away! |
				 Posted: Sat Jun 09, 2012 6:22 pm    Post subject:  |
				| I would weld it. Not worth the chance of a leak. Just my two cents. |
